Ok so I installed a new valve cover gasket on my 93 Accord and I go and torque the acorn nuts that hold on the valve cover to 9 ft lbs and 2 of them go smoothly and the torque wrench clicks, then on the 3rd one, before I even get any tension one of them snaps at the smaller end that shows thru the valve cover, luckily not the end that screws into the rocker arm assembly. Then I go to try another one by hand and I get the same thing! Is there something I am doing wrong, or just old rocker arm studs? The car has 226k miles so it's probable they have just gotten old but not too sure. Chilton's manual says 9 ft lbs but I saw a video on YouTube and the guy does it by hand so maybe I should do that? He mentioned tighten until snug but on the last 2 I never even felt any significant resistance and then they broke :/ please help!
Why do I keep snapping my rocker arm studs?
Originally posted by Darkcloud View PostYoure over tightening them go hand tight slowly.
Ive done it my way no issues
are the studs and nuts clean and oil-free when you try to install them? oil can make the resistive force against the torque wrench lower, causing the wrench to read lower than the actual tightness of the nut would cause.
Originally posted by Stephen Fry'It's now very common to hear people say, "I'm rather offended by that", as if that gives them certain rights. It's no more than a whine. It has no meaning, it has no purpose, it has no reason to be respected as a phrase. "I'm offended by that." Well, so fucking what?' —Stephen Fry
Originally posted by steelbluesleepR View Postare the studs and nuts clean and oil-free when you try to install them? oil can make the resistive force against the torque wrench lower, causing the wrench to read lower than the actual tightness of the nut would cause.
Note: The 1993 OEM manual calls for 7 ft-lb for these nuts. I suggest tightening them a turn or two at a time in a criss cross pattern to pull the cover down evenly.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
i've had this happen to me as well.
what kind of torque wrench are you using exactly? if you're using a big ol' 2ft long ratchet with a 1/4 drive then it's probably puttin alot of force down on the bolt/stud. way more than needed. using a smaller tq wrench would help out, one that has increments of inch-lbs.RIP '91 LX.
Originally posted by fleetw00d View PostFor a typical bolted joint, about half of the torque is taken up by friction between the nut and the flat surface, 40% by friction in the threads, and only 10% actually goes into creating the preload in the joint. With oil on any of the friction surfaces, less torque is used overcoming friction and more of it goes into preload, so even using a torque wrench, you can get much more load in the joint than intended.
Originally posted by steelbluesleepR View Postyeah, that's what I meant, I apparently couldn't form coherent sentences this morning!90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
Originally posted by CrunkRuffRyderz View PostOk so I installed a new valve cover gasket on my 93 Accord and I go and torque the acorn nuts that hold on the valve cover to 9 ft lbs and 2 of them go smoothly and the torque wrench clicks, then on the 3rd one, before I even get any tension one of them snaps at the smaller end that shows thru the valve cover, luckily not the end that screws into the rocker arm assembly. Then I go to try another one by hand and I get the same thing! Is there something I am doing wrong, or just old rocker arm studs? The car has 226k miles so it's probable they have just gotten old but not too sure. Chilton's manual says 9 ft lbs but I saw a video on YouTube and the guy does it by hand so maybe I should do that? He mentioned tighten until snug but on the last 2 I never even felt any significant resistance and then they broke :/ please help!
Now that you all mention it, the studs were full of oil, and my torque wrench is the long one about 2 feet long. I purchased new studs and had a local Honda tech show me how tight I should make them. Everything is in working order now and I will definitely take this as a lesson for future projects and hopefully this can help someone else in need of this information
