My buddy and I are doing his Valve clearance and We know the specs and I've read and re-read the hayne's manual and watched eric the car guys video...but here's the issue
All the Valves seemed too tight after we changed his lower spark plug tube seals so I figured we would do the valve lash because now it had a valve tick that wasn't there before.
I am Turning the engine over by the PS Pump and the exhaust valve closest to the Cam gear is snapping(lack of a better term) shut every time it opens cause I went around and did all the intake side first then I was gonna do the exhaust side last and then double check afterwards.
any thoughts on whats going on?
is it just that, that exhaust valve is too tight and I just need to finish?
side note:we did try and start the car after the tube seal change and it was snapping closed really fast so we cut the engine ASAP...its not a DD at the moment due to my buddy not having his licence so we're in no rush to fix it.
Info
289000km
Auto
original engine and tranny
no mods, bone stock EXR
Info
289000km
Auto
