hey i am about to buy a f23 vtech cause my f22 is blown, i need to know what the extent of the swap is and ect. i have a 1997 honda accord EX the f23 engine came out of a 1998 honda accord
F22 VS f23 vtec
Well, why would you not try and put another F22A in?
I would use the F23 block and F22 head and then you don't have to worry about doing a swap as it is a direct bolt in then plug-n-play setup for a CB7.
F23 would need an ecu at the very least.
EDIT: are you replacing an F22A or F22B?Last edited by wildBill83; 08-21-2013, 01:08 AM.1993 SE Coupe MRT - 1992 LX Sedan MRT
It's vtec for the record lol but wildbill is right. If you don't have the funds to replace the f22 just swap the head over. It's simple and you have everything you need. Just get a gasket set and all your fluids. Make sure to check belts, maybe grab a new water pump if it's never been replaced and has a lot of miles, plugs, wires, and anything else that could be worn. Might as well get it all right and squared away while the motor is out.
Originally posted by wildBill83 View PostWell, why would you not try and put another F22A in?
Also the F23 block is 86mm, F22 block is 85mm.
Also there is no H in VTEC.
My 5.7 LS1 Holden Ute
Originally posted by eank View Postwell i have a CD7 i accadently went to the wrong website.. but anyways, i have a f22B
Also http://www.hondaaccordforum.com/foru...gen-5-a-47757/Last edited by wildBill83; 08-21-2013, 08:41 AM.1993 SE Coupe MRT - 1992 LX Sedan MRT
