vouches:
Bought from: Smeagren83(quite a few times now LOL), 97lude, AZaccord, M3torz2nR, g7kobayashi, sickoffthe206 and Kurobei, Jarhead, prNonVtec4u, caserX
Sold to: Snailin91, Smeagren83, cb7dazz, Drummersteve7, Slick
no its not cause replacing tires every threes months because of camber wear is a waste
that, and unless you know what ur doing and have a quality susp setup, and dialed in...slamming it surely throws off the susp. geometry and causes the car to handle worse, even in comparison to factory specs.
all these people that say to dump it... just care about the "look" of the car rather than the actual function.
With my new wheel/tire package...and spacer combos i could use a SLIGHT drop from where it sits now...and then some minor alignment changes. Cant go much lower though..i already scrape the zero lift undertray and im not about to fuck up a 400+ CF lip.
/rant
then don't I doubt your wheel gap is that bad if you're talking about .3" and .5"
vouches:
