Old 05-19-2017, 04:44 AM   #1
WagonMafia206
Newcomer
WagonMafia206 is cool... so far.
Header/Downpipe Removal 1 Piece Possible?
Was trying to remove my OEM downpipe and header(Not sure if CB7 or Prelude since its swapped). Im starting to strip my nuts that hold the downpipe and header together.
~Is it possible to remove these pieces connected?~
No, I havn't used PB blaster yet, or a breaker bar. I figure if they're stripping just on a 1/2 drive socket the breaker wont help. Possibly the PB will, but it seems rusty as heak.
WagonMafia206 is offline   Reply With Quote
Old 05-19-2017, 06:16 AM   #2
GhostAccord
CB7tuner Member
GhostAccord seems to have made some friends! GhostAccord seems to have made some friends!
Sorry, there is no way to get them out in one piece.
Heat is your best friend when it comes to working on stubborn exhaust studs and nuts. I use benz-o-matic MAPP Gas (Yellow). Heat the nut up cherry and hammer on the next size down socket. Should back off without any issues.
__________________
MR Thread
GhostAccord 2.4L Blog
by Chappy, on Flickr
GhostAccord is offline   Reply With Quote
Old 05-19-2017, 06:14 PM   #3
WagonMafia206
Newcomer
Well thats not too bad. About how long to heat up the bolts under heat?
Old 05-19-2017, 10:16 PM   #4
GhostAccord
CB7tuner Member
Usually if I'm using MAPP gas I only have to heat it up for a minute. If it doesn't break loose right away, just heat it up for a bit longer. After you heat it up it shouldn't take much pressure to break that initial hold.
__________________
MR Thread
Old 05-22-2017, 01:02 PM   #5
G. Wiffington
CB7tuner Member
G. Wiffington is cool... so far.
Do you have access to air tools? An impact gun makes it 1000 times easier as well.
I know when I disconnected my header & downpipe I had to let my impact gun really get at
the bolt for a minute or two so that it could break the bolt loose (along with a ton of PB Blaster).
G. Wiffington is offline   Reply With Quote
Old 05-22-2017, 05:41 PM   #6
deevergote
Don't call me dude.
deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool...
Send a message via AIM to deevergote
Couldn't you drop the entire thing in one piece if you removed the front crossmember and lifted the front of the car sufficiently?
I believe there was at least one expensive H22 header that was a one-piece design. Installing it was a hassle, but doable. I'd assume if a performance header with larger primaries can be installed that way, the factory part must be able to come out the same way.
Still, getting it out in two pieces would probably be the easier route, even if you have to use fire to do it.
__________________
BUY MY STUFF!!!
NEW PRICES ADDED 09/24/2016
AEM TruTime cam gears (H22A), DSM 450cc injectors, Eaton M45 superchrager
deevergote is offline   Reply With Quote
Old 05-22-2017, 05:51 PM   #7
GhostAccord
CB7tuner Member
You would probably need to lift the car at least 2' for it to clear enough to drop it through the bottom. If one has access to a hoist, you could drop the cross member and drop the header though the bottom.
__________________
MR Thread
Old 05-23-2017, 09:42 PM   #8
fleetw00d
Contributing Member
fleetw00d seems to have made some friends! fleetw00d seems to have made some friends!
If it can't be lifted enough, could one get enough room by removing the lower cross member, radiator, and upper radiator support?
__________________
90 LX 4dr 5 spd 360,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
93 LX wagon auto 241,000 MRT:http://www.cb7tuner.com/vbb/showthread.php?t=208490
92 EX coupe auto 167,000 - MRT:http://www.cb7tuner.com/vbb/showthread.php?t=205114
LOTS of CB7 parts for sale http://www.cb7tuner.com/vbb/showthread.php?t=192583
Working to relink my pictures. Please be patient. If there is one you particularly want to see, let me know.
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
