Ok so heres what i did, i took it to my schools autoshop and i got to work on it for a few hours. First, i bled the cooling system and it still idled from 800-1500. next i removed my IACV and my shop teacher told me to clean it with brake cleaner and let it sit for a while. we also unscrewed the plate on the back of the IACV and found that the gasket was TOASTED. so we used some RTV and let it sit for the day. it sealed up fine. we put every together and back on. i drove it home and its still idleing the same. Can anyone please help!
Idle problems Still...
does the check engine light come on?AT WEST COAST MEET
cb7rush: who has the tongs?JDMxDB8: i got a thong on...
to get to see more of my cb click the link below.
http://www.cb7tuner.com/vbb/showthread.php?t=130922
Originally posted by stretch JDM View Postexhaust leaks are no good need to get that fixed man. it all depends how long it has been leaking. a leak can warp you valves. does it cut out when under acceleration ? it could be the idle screw need adjusting.
Originally posted by Drifting in 808 View Postthats a negative, BTW this is a H22a1AT WEST COAST MEET
Originally posted by Drifting in 808 View PostOnly known hose that is missing is a hose on my CAI that was taped up. but there is a hose that goes from my CAI to my valvecover.MRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfucker
Check the FITV first before buying any new parts. this is one of the most common things that go wrong and is easily fixable so long as the part still functions.
1) warm up your car to operating temperatures, and until you are sure the Fast Idle Thermo Valve (FITV) on the Throttle Body is thoroughly warm.
2) remove the TB or FITV, however you want to get to the FITV, and unscrew the screws that hold on the gold cap on the FITV
3) use two flathead screwdrivers and turn the wax ring in the FITV down (righty tighty) and immediately stop when the wax ring ceases to go further. If you want to be safe, back it out slightly after its been tightened just in case.
4) close up the FITV and reinstall.
Tightening the wax ring helps to create an airtight seal, which the FITV is supposed to have when your engine is fully warm. the FITV allows air in during the beginning warm-up and then the wax ring expands due to heat and seals it shut (or so i've been told). This is the reason why you tighten it when its hot and not when it's cold, because the part may fail if its overtight.
Some Symptoms:
The FITV leaking generally causes a hunting idle and high idle, 1100+ usually. Sometimes your idle does settle after a while, but pressing the throttle pedal down will bring back the hunting idle. The hunting idle typically occurs when your car is in park or neutral. in reverse or in gear, the idles are just high.
good luck!
Hmm thanks, i will try this tomorrow. because what your saying sounds exactly like whats happening. if i warm my car up and dont press on the gas the idle is fine. once i touch the throttle, it starts to do it agian and keeps on doing it till i shut it off. And just in case if i do have to replace my IACV wheres the cheapest place i can get one. i know napa sells it for 313$ and i dont got that kind of money. lol
