Integra Owners!
    Integra Owners!
    I'm calling out all Integra owners! 1st, 2nd, 3rd, and 4th generations! RSX owners, yes that means you too!
    All Integra owners check in!
    Driver Name: Matt
    Car Name: Isabella
    Purpose:
    1) Canyon carving
    2) Daily driving
    3) Road racing
    Engine/Drivetrain:
    B18C1 (206,XXX miles)
    AEM short ram intake
    A'PEXi World Sport 2 cat-back exhaust
    DC Sports ceramic 4-2-1 one-piece header
    Energy Suspension shifter bushings
    Koyo OEM radiator
    Mugen fan switch
    Mugen thermostat
    NGK Laser Platinum spark plugs
    NGK spark plug wires
    Spoon Sports baffled oil pan
    Spoon Sports radiator cap
    Spoon Sports magnetic drain bolt set
    Suspension:
    ASR rear subframe reinforcement brace
    ASR 24mm rear sway bar
    Carbing front strut tower bar Type II
    Carbing front lower arm bar
    Carbing rear strut tower bar
    Carbing rear lower arm bar
    Function 7 rear lower control arms
    TEIN Flex Damper
    Brakes:
    Goodridge G-Stop brake line kit
    Motul RBF600 brake fluid
    Power Slot slotted rotors (front/rear)
    Project Mu Type HC Plus brake pads (front/rear)
    Wheels/Tires:
    OEM GS-R Fat Five (polished, 15x6) - In storage
    Volk Racing RE30 (bronze, 15x7, +35) - In use
    Falken Azenis RT-615 205/50/15 (front/rear)
    Rays Engineering lug nut set
    Exterior:
    Amber front turn signal lenses
    Benen Industries tow hook set
    JDM Integra SiR-G front and rear "H" emblems
    JDM Integra antenna delete plug cover
    JDM "HONDA" rear trunk badge
    Xenon Visions HID Conversion Kit 8000K (low beam)
    Interior:
    Amber gauge cluster bulb conversion
    Bride Zeta III bucket seat - driver
    Bride seat rails
    Broadway rear view mirror
    Carmate Air Spencer (blue squash ftw!)
    JDM ITR shift boot
    Momo Tuner 320mm steering wheel
    Momo steering wheel hub
    Spoon Sports 5-Speed duracon shift knob
    Electronics:
    Garmin Nuvi 200 GPS
    Sony Xplod head unit
    Viper 1002 security system w/ keyless entry
    Raceline USA
    nice mod list
      any more pics of your car?
        Originally posted by oneoffaccord
        nice mod list
        Thank you sir.
        Raceline USA
          http://www.cb7tuner.com/vbb/showthread.php?t=100299
          Raceline USA
            That is a nice mod list. I drove a 94 white LS sedan on some ugly 17's that rubbed everywhere...does that count? I had it for like 2 weeks.
              Thanks. I try to keep my DB8 clean and simple.
              Raceline USA
                Nice
                I have a 94 gsr, it's not much of a looker though
                right now im changing parts that will make it run forever before i do too much performance
                so far I've changed timing belt, water pump, belt tensioner, clutch, t/o bearing, fuel tank, master cylinder, slave cylinder, both axles, dc short shifter, average intake, neuspeed strut bar, rear strut bar, itr shift boot, itr shift knob, ricer HIDs, couple other things that i cant remember
                right now im rebuilding a gsr swapped civic, it's taking up most of my modding ATM
                94 GSR | 93 GSR
                  Originally posted by JYardBandit
                  Nice
                  Nice DC2 man. I'm planning to keep the B18C1 in my DB8 and just keep it as a DD. I'm planning to get a 97 Type R and turn it into a weekend road racer. A K20A2 will be the DC2's powerplant.
                  Raceline USA
                    http://www.cb7tuner.com/vbb/showthread.php?t=101646
                      reporting in.
                      lol
                      峠 で ドリフト を して 下さい。
                      steam linky facebook, y0 俺 は 走り屋 です。 clickable ^
                        used to be
                        http://www.cb7tuner.com/vbb/showthread.php?t=66929
                          looks like a fun thread. ill check in when i get home.
                          TYPE R Big Build thread 25,000+ VIEWS!!!http://www.cb7tuner.com/vbb/showthread.php?t=123069
                          I feel like BIG MEECH! LARRY HOOVER! whippin work! haileliuah one nation under god. REAL naggas gettin money from the freakin START!
                            Originally posted by JaK FRoSTWhiTE
                            Pretty clean man.
                            Raceline USA
                              Anyone else own an Integra?
                              Raceline USA
