You'd sure think with the amount of Hondabond they use to seal up these cars you wouldn't have problems with rust right? Wrong. We all know the popular spots on CB for quarter panel's to rust out.
I just got done ripping some quarters off to use as replacements for the DD. What I found is that Honda only seals the rears up about a quarter of the way up the back side of the inner wheelhousing.
(Red Circle shows sealant on wheelhouse)
What that does is keep your trunk dry, lol.
They also seal the bottom and rear seams where the skin is tacked onto the frame.
(Red Circle shows areas that are sealed)
They DON'T, however, put any sealant on the inside of the wheelhousing it's self. So what happens is all that water coming off your rear tire seeps up in there and has no where to go. It just sits.
(You can see where the Hondabond was (in red circle), and you can also see a bit of surface rust (circled in blue) that just happens to start right where the Hondabond stops.)
My suggestion to all those who DON'T have any cancer on their cars is to go out with a 1/4 inch drill bit and start drilling holes along the bottom side of the quarter where the bumper is and also underneath the side molding under the rear doors.
(Above the bumper, red arrows denote)
(Below the door, again Red arrows denote)
That will allow any water that manages to make it up in there to have a way out so that it doesn't just pool and corrode.
I would also suggest a thin bead of sealant along the inner fender lip in the wheel well to try and prevent some of the water from getting in there in the first place.
(Circled in Blue this time, ignore the red)
I realize there's other sections this could go in, but I feel it'll get the most views here......
That is all.
Rob
That is all.
Rob
Just messin' wit ya East Coasters....
