Thread Tools Rating: Thread Rating: 5 votes, 5.00 average. Display Modes
Old 03-03-2010, 04:17 AM   #1
Hostile
Hostile is cool... so far.
EXT : Stanley Yellow Fog Caps
Here is a simple DIY on how to install yellow fog caps in your 9091 OEM fog lights. Thanks to Warudakumi for this DIY.
You have to have the fogs off in order to begin.
Carefully remove the lens from the housing with a heat gun and a flat head screwdriver.
When you have them apart, remove this metal bulb cover from inside the fog light.
This is the yellow fog cap.
It comes apart in 5 diferent pieces. You will only be using the H3 bulb, yellow cap, base ring, and spring
The OEM fog light has 3 i slits were the new base yellow cap, and spring will fit perfectly and twist on. Its like it was meant to be from the factory.
Make sure you wipe the bulb and reflection area gently before you put the lens back on. Use some sealant so the fogs wont have any leaks
Bad camara phone pic. But they do light yellow and are pretty bright.
2013 Honda Fit Sport Alabaster Silver Metallic GE8
2013 Accord Sport Modern Steel Metallic CR2
CB9 http://www.cb7tuner.com/vbb/showthre...hlight=hostile
CR2 http://www.cb7tuner.com/vbb/showthread.php?t=197787
GE8 http://www.cb7tuner.com/vbb/showthread.php?t=199289
Hostile is offline   Reply With Quote
Old 03-04-2010, 02:10 PM   #2
nate'sCB7
nate'sCB7 is cool... so far.
Nice write up!
nate'sCB7 is offline   Reply With Quote
Old 03-04-2010, 03:04 PM   #3
Juan4DCB7
Juan4DCB7 is cool... so far.
would this work for 92-93 fogs?
Originally Posted by visualpoet View Post
some owners think it's the best thing since titties
Juan4DCB7 is offline   Reply With Quote
Old 03-04-2010, 03:47 PM   #4
busak87
busak87 is cool... so far.
Send a message via MSN to busak87
^^yup!! I did the same!!
good write up too
Originally Posted by slammed4thgen View Post
be risky, be smart, and most of all be creative!
busak87 is offline   Reply With Quote
Old 03-05-2010, 12:19 AM   #5
Hostile
Originally Posted by nate'sCB7 View Post
Nice write up!
Thanx
It should if they take the H3 bulbs but im not sure.
Old 03-05-2010, 02:05 AM   #6
Kurobei
Kurobei is cool... so far.
Yup they work with USDM/JDM 90-93 Fogs
I need a custom turbo manifold built....
707 NorCal NinjaZ
Honda Twincam Motorwerkz?
"I am the Yakuza CB7!"
'92 Accord Sedan SiR
Kurobei is offline   Reply With Quote
Old 03-05-2010, 02:42 AM   #7
Darkcloud
Darkcloud is cool... so far.
any night pics?
Darkcloud is offline   Reply With Quote
Old 03-05-2010, 04:52 PM   #8
illestatus
Accord of the Month: July, 2010
illestatus seems to have made some friends!
Send a message via AIM to illestatus
you dont need to remove the lenses to replace the yellow caps(for 90-91fogs) or to remove the metal plate that is inside.
illestatus is offline   Reply With Quote
Old 03-05-2010, 06:23 PM   #9
cloudasc
cloudasc is someone to admire cloudasc is someone to admire cloudasc is someone to admire
x2
cloudasc is offline   Reply With Quote
Old 03-05-2010, 07:53 PM   #10
F20A CB7
nice, i dont have stanlys, i have lexus i think, so for me have to drill out the spot welds. i want the lense to fit flush against the housing
Old 03-16-2010, 10:53 PM   #11
blackfoedoecb7
blackfoedoecb7 is cool... so far.
I actually sprayed mine with the amber glass paint and took a blow dryer to them and put the really bright bulbs in them.
blackfoedoecb7 is offline   Reply With Quote
Old 03-21-2010, 01:13 AM   #12
kouzie
kouzie is cool... so far.
gotta try this but my yellow bulbs are just too
Great stuff..
kouzie is offline   Reply With Quote
Old 01-08-2012, 06:46 PM   #13
Hostile
Just did this again not to long ago with my 9091 and had great results. Next time I'm going to try it without opening up the lights, if they don't need restoring.
Old 10-22-2012, 04:26 PM   #14
CB7 R3ason
CB7 R3ason is cool... so far.
sorry to bring this DIY back up but do you have to cut the metal shield out in order to fit the yellow caps in 9293 fog lights thanks
MR : http://www.cb7tuner.com/vbb/showthre...ght=CB7+R3ason
Originally Posted by quaidum View Post
you being able to see four blocks down the road is resulting in someone not being able to see 5 feet in front of them
good job, just what the world needs more inconsiderate drivers
CB7 R3ason is offline   Reply With Quote
Old 10-28-2012, 10:10 PM   #15
Hostile
You don't have to, but it makes the lights a little brighter.
Old 10-30-2012, 09:48 AM   #16
speedfr3ak
speedfr3ak Needs to slide down a razorblade into a pool of alcohol, and then be set on fire. speedfr3ak Needs to slide down a razorblade into a pool of alcohol, and then be set on fire. speedfr3ak Needs to slide down a razorblade into a pool of alcohol, and then be set on fire.
hows the lighting bro?
This thread is over a year old, you fucking retard.
i dont know why this popped up but U MAD BRO? not my fault u is FAKE! CLOWN ASS
speedfr3ak is offline   Reply With Quote
Old 02-03-2015, 03:54 PM   #17
1badacc
1badacc is cool... so far.
bump!
^^MY OLD RIDE
http://www.cb7tuner.com/vbb/showthre...91#post3052591 <<**CURRENT DA9 BUILD**
1badacc is offline   Reply With Quote
