Tools needed:
Jack
Extra tire
19mm socket
Socket wrench
(Maybe) Breaker Bar
Remove any hub caps. Break loose the 4 (5?) lugnuts. Use the breaker bar is needed. If you haven't removed the tire in a while drive the car back and forth about 5 feet.
Jack the car up and remove the lugnuts the rest of the way.
Remove the tire and place new tire of the bolts.
Hand tighten all lugs. Then tighten them all the way using the socket. Tighten opposite lugs until they are all tight.
Lower the car and re-tighten the lugs using the same pattern. Tighten them to 80 ft lbs. Lacking that, tighten them well, but not over tight.
Clean up
Jack
Extra tire
19mm socket
Socket wrench
(Maybe) Breaker Bar
Clean up
