Old 03-21-2011, 10:18 AM   #1
Tippey764
Silver Member
EXT: Heated mirror glass install
So i decided to get smart and just type everything on the pictures
This is only for installing the glass, not wiring them to actually work. That will be another DIY
Materials:
1996-1998 acura 2.5/3.2 heated mirror glass
solder
shrink tube
about 2 feet of thin wire
Tools:
Philips screw drivers
flat blade screw drivers
soldering iron
oven
hands
brain
YOU WILL NEED TO KNOW HOW TO SOLDER, using cheap shit clips is not an option due to the small space inside the mirror and interference that could be created by a large wire clip thingy.
Tippey764 is offline   Reply With Quote
Old 03-21-2011, 01:18 PM   #2
93SM4_CB7
93SM4_CB7 is cool... so far.
Send a message via AIM to 93SM4_CB7
Very Detailed , Great Write up !!!
Check Out My Work In Progess . . . . .
93SM4_CB7 is offline   Reply With Quote
Old 03-21-2011, 01:31 PM   #3
MikeW
Master Of Posting Nothing
MikeW has a HUGE cock! MikeW has a HUGE cock! MikeW has a HUGE cock! MikeW has a HUGE cock! MikeW has a HUGE cock!
Send a message via Yahoo to MikeW
I give you big props for doing this and making the DIY but this seems like SO much trouble... Maybe it's just me, lol.
KeepinItClean | EnviousFilms | NoBigDeal | YET2BSCENE | . ` ' / . | click here.
Originally Posted by Jarrett View Post
MikeW is offline   Reply With Quote
Old 03-21-2011, 10:48 PM   #4
Tippey764
Silver Member
thanks
It only took me about an hour to do one mirror, and that included taking my time and taking pictures
Old 03-28-2011, 01:39 PM   #5
Noridetoolow
Noridetoolow is cool... so far.
Awesome DIY but I agree....seems like a lot of freakin work! lol Good thing I live in the south....rare are the days when the mirrors have ice on them anyway!
Bought from Darkcloud
http://wheelflip.com/r/DrAkE
Noridetoolow is offline   Reply With Quote
Old 03-28-2011, 02:17 PM   #6
Dobermann
Dobermann is cool... so far.
Great write up!
I may have to grab some of these from the yard soon.
Did you get the switch for it too?
Dobermann is offline   Reply With Quote
Old 03-28-2011, 02:40 PM   #7
vietkid_2006
vietkid_2006 is cool... so far.
Send a message via AIM to vietkid_2006 Send a message via MSN to vietkid_2006 Send a message via Yahoo to vietkid_2006
I can't finish my mirrors until I find my switch...lost it somewhere..
vietkid_2006 is offline   Reply With Quote
Old 03-28-2011, 06:33 PM   #8
Tippey764
Silver Member
If you can find the switch from a 97-99 acura CL it is a direct swap for an accord
the heated mirror switch has a seperate connector so no need to add any wires into your stock green connector
Old 03-28-2011, 06:38 PM   #9
Ralphie
Stalker
Ralphie is damn fine. Damn fine, indeed. Ralphie is damn fine. Damn fine, indeed. Ralphie is damn fine. Damn fine, indeed. Ralphie is damn fine. Damn fine, indeed. Ralphie is damn fine. Damn fine, indeed. Ralphie is damn fine. Damn fine, indeed.
Good work mate!
Your DIY are some of the most refreshing we've had!
Keep it up!!!
Ralphie is offline   Reply With Quote
Old 03-28-2011, 07:01 PM   #10
Tippey764
Silver Member
Originally Posted by Ralphie View Post
Good work mate!
Keep it up!!!
Will do sir!
one of my next planned DIY is a digital climate control swap, im just waiting for someone to pull through and get me the climate control stuff in new zealand
Old 03-28-2011, 09:34 PM   #11
tommi
Accord of the Month: August 2011
tommi seems to have made some friends!
It's just u.
(128)Transactions and counting
tommi is offline   Reply With Quote
Old 03-28-2011, 11:07 PM   #12
vietkid_2006
I have the newer J32 CL switch somewhere think that will work?
Will do sir!
I have the digital climate thingy...in a box somewhere also lol.
Old 03-29-2011, 01:19 AM   #13
Tippey764
Silver Member
01-03 acura cl?
yes it CAN work but you will need to cut and splice wires that you already have, my preference is to touch stock wiring as little as possible
how about you sell me that DCC
Old 03-29-2011, 10:38 AM   #14
vietkid_2006
01-03 acura cl?
So the earlier CL's have a separate connector for the mirrors?
I've only seen like two CL's here but they were hit on the drivers side and the door panel is no where to be found with the switch.
About the climate control, PM me.
Old 03-29-2011, 01:04 PM   #15
Tippey764
Silver Member
The mirror switch uses 7 wires and the heated mirror uses 2 wires
In the later acura honda cars they have one connector of 9 wires, the 97-99 acura CL is on the left and the stock one is on the right
that is a female 2 pin connector hanging off out of the picture a bit
Old 03-29-2011, 01:43 PM   #16
vietkid_2006
Makes perfect sense now thanks, if you find one you should let me know since you probably have more CL's over there than over here.
Old 04-10-2011, 03:25 PM   #17
Tippey764
Silver Member
I made a revision and pinned the connector with 2 extra pins so it looks cleaner
Old 04-10-2011, 04:11 PM   #18
illestatus
Accord of the Month: July, 2010
illestatus seems to have made some friends!
Send a message via AIM to illestatus
nice diy, ive replaced my mirrors with heated ones as well....i dont want to get the switch because my mirrors are power folding(i have that switch), so i will eventually hook the heated mirrors up to the defroster switch. also instead of using an oven you can also use a heat gun.
illestatus is offline   Reply With Quote
Old 04-10-2011, 08:15 PM   #19
Tippey764
Silver Member
That was one way to do it
when i make a wiring diagram for people to follow i will include both ways to do it, i wired mine up to an OEM switch, well you know that because you bought it for me lol
Newer honda's seem to have done away with the heated mirror switch, the newer TL's and RL's rear window defogger and mirror defogger are both togeter.
Oh and don't your mirrors have a blue tint to them? Mine don't.
Old 04-13-2011, 02:17 PM   #20
GeoffM
Administrator
GeoffM seems to have made some friends! GeoffM seems to have made some friends!
Looking forward to the sequel. I just got a pair out of a Legend, but the switch I have doesn't look like it'll fit. I think I might wire mine to my main defroster.
MRT
sneaky motherfucker
GeoffM is offline   Reply With Quote
