Engine/ Exhaust:
H22a
T2T4 trans
Fidanza flywheel
Spec stage 2 clutch
Poly filled engine mounts
Kaizen speed manual tensioner
Ebay header
short ram intake
Kteller 2.25 stainless pipe
Vibrant dual outlet muffler
Vibrant resonator
Wheels/ Suspension:
Autostrada Modena 16x7 16x8
Dunlop DZ101 195/50/16
Function and Form Type 2 coilovers
Ingalls ball joint front camber kit
Eibach rear upper control arms
Prothane Bushings
-Front and rear sway bar
-Front lower strut mount
-Front lower control arms
-Front upper control arms
-Ball joint and tie rod boots
New wheel bearings and hubs
Blackworks extended wheel studs
Muteki Extended lug nuts
Sprint suspension front strut tower bar
Ebay rear strut tower bar
Brakes:
Apex stainless brake lines
Exterior:
Black housed oem headlights with Yellow high beams
Blackhoused oem corner lights
Blackhoused oem bumper lights
JDM CB sidemarkers
CD5 rear sidemarkers
Ebay window visors
92-93 Sedan Trunk with oem led spoiler
Jack Lee grill
55w 6k HID low beams
35w 3k HID high beams
Acura Legend coupe lip
Oem front and rear mudflaps
Interior:
Nardi woodgrain steering wheel
Prelude short shifter
Ebay green shift knob
Ebay black suede shift boot
Pioneer headunit
Pioneer 6.5 door speakers
Pioneer 6x9 rear deck speakers
Pioneer 1in door tweeters
Oem 90-91 arm rest
Broadway 270mm rearview mirror
Future Plans:
Paint and body
A few other things here and there
Here's the current look
The Beginning
Got this car for free from a family member. I was told it didnt run and needed a clutch, it also has a bit of body damage. We went to go pull it out of the yard its been sitting in for almost 2 years, all of the brakes were locked up. Once we got it rolling we pulled it back to my house. Everything power worked but it wouldnt turn over so I had the starter tested. Came out good. So I took a jumper wire and jumped the starter and what do you know, fired right up and runs issue free even after sitting for so long. All power windows work, power locks and sunroof works, a/c works, ps and radio everything works. Got around to bleeding the brakes and its missing the pass. front caliper and they have a screw jammed into the line, but the brakes do work. Fired it up after we found the brake problem and drove it around the block. The car does not need a clutch or anything really. I'm guessing they stopped driving it because it wouldnt start. I also found a huge pile of service records in the glovebox, awesome! You really can't beat it for free. Anyways, heres some pics. This is my first car but i'm far from new to the automotive world, just more experience with mini trucks. I dont think i'm going to do a whole lot with it other than clean it up and drop it with some nice new paint, but you never know how these things go. I'm not used to being able to actually find parts for my vehicle hahaha.
some damage
Here's one with my trucks
