Sold as of June 2014.
My ride, a 1990 Accord EX coupe with M/T from Washington State, and this is my journal recording my progress and thoughts on the project.
Below is a brief time line starting from recent to the beginning and will hopefully continue to expand.
April, 2014
October, 2013
July, 2013
January, 2013
ENGINE
SUSPENSION
EXTERIOR
INTERIOR (Going to redo eventually.)
PLANS
I recently purchased this car in January and have been slowly building onto it, though not much has gone into it so far, I have been doing a lot of basic maintenance, such as random gaskets, belts, and fluid changes (Have not done brake fluid yet but have not needed to). Bought it at 201,000 miles and I am at about 205 now. I have had problems with the previous head and I ended up paying more than expected both money and time due to unforeseen circumstances, but it is healthy now and pulling strong.
After I pulled the head. Not too clean but at 200K miles, I was not expecting much.
Not too pretty in the cylinders either. Pistons were in decent condition so I left them in, just cleaned out all of the gunk.
This is a picture after one day of cleaning, I have done more since then, but not too much, de-greasing of some parts. Still is too dirty for me and I want to eventual do a wire tuck
Update: Engine bay as of April, 2014.
From this:
To this:
Snapped some photos since Seattle has been lucky enough to have sun this past month and 80 degree weather. Not a common occurrence.
The wheels are Motegie MR12. I got them out of a junk yard for $200 and had scratches and curb rash all around and on all 4 wheels so I did my best to fix and repaint them and they all turned out nice. There is still evidence of the damage that used to be but they are good enough for me.
This was when my baby was limping and the camshaft snapped shortly after, also I had 3 different tires on there at the time I took this photo. The two in the front were matching but the two in the rear were old tires that worked for what I needed since the someone I think slashed them beyond repair, but they were smaller than the front and one of the tires were wider. surprisingly stable and I have been riding like that until I replaced all four tires. Oddly enough what caused me to replace those was that one of the good tires went bad, not the junkyard tires.
This is my project and I want something at the end that is decently competitive in autocross, comfortable enough to be a daily commuter, and reliable enough to not have a car payment for awhile.
Update: I am now planning to do an H23 swap with most components rebuilt.
Update: Screw it! I'm going balls to the wall H22!
April, 2014
October, 2013
July, 2013
January, 2013
ENGINE
- AEM SRI
- Re-manufactured Head
- New Valve-train (OEM Spec)
- Radiator & Hoses
- M2S4 Swap
- New Exedy Clutch
- Maintenance & Cleaning (Best bang for the buck)
- A/C Delete
- More Grounding Points
- Minor Wire Tuck
SUSPENSION
- 17" Motegi MR12 Wheels
- Champiro UHP1 Tires 205/45R17 (Tire Wheel Combo ~39lbs)
- Koni S.trt Struts
- Vogtland Springs 1.6"
- Acura CL ROH Knuckles
- Acura 2.3 CL Rotors
- Acura 3.0 CL Rear Suspension (Awaiting Install)
EXTERIOR
- Repainted Trim
- Black Painted Factory Grill
- Black Housed Head Lights
- Antenna Delete
- White Headlights (4500K?)
- Clear Corners (LED Lights)
- 92-93 Front Bumper (90-91 Headlight & Grill)
- Clear Bumper Lights (LED Lights)
- Removed Pinstripe
- Painted Wheel Well and Suspension Components (Fronts only for now)
- Rattle Can Black/Grey Interior (Was tan.)
- Custom Window Antenna (Needs refinement.)
- Cheap Generic Floor Mats
- Car Seat Covers
- Ebay Shift Knob
- Blindingly Bright LEDs
- 90-91 Prelude Si Steering Wheel
PLANS
- Legend Dual Piston Calipers
- H22A or H23A VTEC
- Entire Exhaust System (Still deciding on brands)
- Suspension Replacement and Reinforcement
- Rear Disc Conversion (Got the parts)
- High Compression Pistons
- Stronger Connecting Rods
- AEM Fuel Rail
- Strut Tower Braces (Front and Rear)
- Limited Slip Differential (M2S4 Drop-in)
- Light Weight Pulleys
- Thick Sway Bars
- Polyurethane Mounts
- Smaller Radiator Fans
- Manual Steering Rack
- Touch-up Paint Job (Maybe)
- Many Small Things
From this:
To this:
Looks like you have a pretty clean car to start out with. I also see that your future plans list has grown significantly since the last time I looked lol
