Well I got a replacement for the CB, probably will get another after some time but for now this will serve as my daily.
Below will be a timeline of the progress.
March, 2015
September, 2014
May, 2014 (When purchased)
Its a 1995 E34 with a slush box for now but it was cheap and great body, phenomenal paint, no rust, and the best part 160K miles.
The main issue as to why it is so cheap is the transmission goes into limp mode sporadically (something electrical is wrong), which I do plan to do a manual swap after awhile, but if I can fix the problem cheaply it will at least buy me some time to find a great bargain on the manual parts needed. Another little thing that will be annoying is no real cup holder. The HELL?!
Here are some of the pictures from the craigslist ad.
Here is some more current pictures of the work so far.
Engine and Drivetrain
Suspension and Brakes
Exterior
Interior
Things That Need Fix'n (Items Fixed)
Manual Swap Progress (Items Completed)
Future Plans
March, 2015
September, 2014
- M50B25TU Single VANOS
- M52 Tubular Steel Exhaust Manifolds
- ZF Manual Swap
- 3.23 LSD
- Single Mass Flywheel Conversion
- Brembo Front Rotors
- Centric C-TEK Rear Rotors
- Stoptech Stainless Steel Brake Lines
- Caliper Rebuild All Corners
- Polyurethane Rear Sway Bushings
Exterior
- E60 Style 138 Wheels
- Repainted Trim
- Red Clear Taillights
- Clear Corners
- Clear Fender Lights
- Painted Bumper Trim Lights
- DIY Stealth Bulbs
Interior
- Factory Parchment (Tan)
- Carpet Dyed Black
- Black Dashboard
- Black Top Door Panels
- Black Suede Rear Deck
- Cheap Generic Floor Mats (Black)
- Black Leather/Vinyl Shift Plate
- Black Suede Pillar Trim
- Black Suede Headliner
- LED Lights
- E32 Rear Headrests
- E32 Rear Reading Lights
- E32 Rear Cigarette Lighter
- E32 Black Leather Shift Handle
- Custom Leather Wrapped Granny Handles
- All the Power Windows
- Loose Fitting Wood Trim
- Brakes All Around
- Hood Props
- Driver Door Panel Falling Off
- Glove Box
- A/C System
- Center Vent Not Sitting Flush
- Fast Battery Drainage
- Sunroof
- Seat Twist
- Blower Motor
- Fog Lights
- Interior Lights
- Power Mirrors
- Gas Lid Hinge
- Shrunken Weather Trim
- Torn Rear Deck
- Steering Wheel
- Driver High Beam
- Paint Issues
- Rust Forming On Trunk Lid
- Front Passenger Door Handle Sticks Open
- Exterior Trim Fits Loose
- It's An Auto
- Acquire Transmission
- Acquire Manual Drivetrain
- Acquire Manual Pedal Cluster
- Acquire Clutch/Flywheel
- Acquire Transmission/Differential Seals
- Transmission Seals
- Differential Seals
- Remove Auto Drivetrain
- Remove Auto Transmission
- Hook-up Clutch Hydraulic System
- Reverse Light Wiring
- Switch To Manual Relays and Misc Wiring
- Install Manual Pedal Cluster
- Shifter Rebuild
- Install Differential
- Install Clutch/Flywheel
- Install Drive Shaft
- Install Transmission
- Install Shifter Linkage
Future Plans
- S50 Camshafts
- 3.1L High Comp "Stroker"
- Volvo Electric Fan
- Whiter Headlights, Foglights, Highbeams
- M5 or M-Sport Front Bumper
- Cup Holder Retrofit
- AUX Input Retrofit
- Dr. Vanos Stage 2 VANOS Unit
- 3.46 LSD Differential
- M-Sport 3 Spoke Steering Wheel
- Euro Bumper Trim
FREE DR. PEPPER!!!!!!
I have a neighbor kid around here with like a 89 525i stick shift has me wanting the dang thing BAD, but I cannot believe how well the wood and leather have held up BMW must not have cheaped out there. Cars seem nice and I always loved the M5 models soooo much
