v8vega355's f22a build
Tags: None
Sweet. What's compression will it be?
Great start to a ton of boost and a ton of speed. Sleeper build?Originally posted by v8vega355 View Postcompression is 9:1 turbo build the pistions and rods are from bisi. same with the clutch and most of the parts
the block has a cnc werx css installed in it once decked it will look almost like a closed deck block
9:1 isn't high compression of course, but I thought u want lower compression for boost
9:1 is perfectly fine, he'll have just as much power out of boost as factory before the turbo gets going. Compression really comes down to the talent of the tuner and the purpose of the build. If you build it right, you can have an 11:1 boost build....or if you want massive amounts of boost, have compression as low as 8:1.'94 JDM H22A: 178whp 146wtq
Originally posted by deevergoteIf you say double dutch rudder, i'm banning you...
not only that but i shouldnt be hardly ever out some kind of boost. it should spool 2500 rpm and be at full boost under 3k rpm. like when first starting off. ive done a few 400hp na domestic builds now i want a torque monster. and i want to do an engine that is not a very popular engine to build.Originally posted by Joey GT-R View Post9:1 is perfectly fine, he'll have just as much power out of boost as factory before the turbo gets going. Compression really comes down to the talent of the tuner and the purpose of the build. If you build it right, you can have an 11:1 boost build....or if you want massive amounts of boost, have compression as low as 8:1.
the last turbo project ended with broken ring lands. it wasnt a popular build either suzuki g10 (cough geo metro engine) it was a factory turbo engine with head work and a cam but 20lbs of boost i think lead to detonation and the ring land failure.
wow i dont get emails when ever i get a new message on my threads sorry.Originally posted by ninjawagon View PostThe 16g turbo your using will be ok for holding power at higher RPM's?
my guess is i will run out of power up top but the cam im running i dont believe is a high reving cam to begin with. ill be using the bisi 1.2 cam i think the cam (from other peoples build using it) is done at about 6500 rpm maybe 7k, im not really building this to be a all out race engine, im building it to be fun to drive from light to light and freeway blast to freeway blast. i went for rides in b18 cars that have huge turbos that spooled at 5500 and pulled to 8500. yea they are super impressive at 6k and up rpm but what happens below all that=boredom.
i want the car that you can be in 5th gear doing 60 and it will smash without having to downshift and without having to worry about breaking stuff in the engine. plus i wanted something different then the 9k rpm civic lol i want a torque monster. something my domestic buddies cant make fun of and still be super fun without sacrificing drivability
