Go Back   CB7Tuner Forums > Site Features > DIYs > Interior DIYs
Old 12-15-2014, 11:50 PM   #1
lucifer1
lucifer1 seems to have made some friends! lucifer1 seems to have made some friends!
INT: Illuminated Window Switches
I have been wanting to illuminate my passenger window switches to match my Legend illuminated master switch panel. After coming across a CR-V in the junkyard with an illuminated master switch(only certain years are), I finally have the means to do it. After that I did the Accord master switch.
Tools
  • Philips Screwdriver
  • Flat Blade Screwdriver
  • Soldering Iron and Solder
  • Drill and Drill Bits
  • Wire Cutter and Wire Stripper
  • CA Glue
  • Shrink Tube and Electrical Tape
Parts
  • 2 CR-V Master Window Switches
  • 7 3mm Leds
  • 7 Resistors To Match Leds
  • 22g Wire
Start by removing the door panels http://www.cb7tuner.com/vbb/showthread.php?t=198613. On the passenger and rear doors remove the single Philips screw from behind armpull and push out window switch.
On drivers door remove Philips screws and spring clips to remove armrest. Then remove the Philips screws holding switch assembly to armrest. Finally remove Philips screw holding to front trim and separate the switch.
Remove the 2 Philips screws from passenger and rear switches then remove front trim
Remove the dust seal
With the dust seal removed you will be able to see the actuator pivots. Carefully pry out the actuator.
This is what it looks like apart
The CR-V actuators have the same mounting points
Install the CR-V actuators into the Accord switch
To illuminate the CR-V actuator, drill a hole for a 3mm led. Don't drill too big or it will need to be glued in.
Press in led and reassemble switch.
To wire the leds there are a couple methods. The proper way to do it is to run 2 new wires into each door and connect to the dimmer. The led positive goes to Red/Blk and led negative goes to Red. This turns on switch backlighting with the lights and dims/brightens with dash dimmer
For those who do not want to run wires nor care if it dims, connect the led positive to window switch ignition feed inside door and ground the led negative wire inside the door.
LF door + wht/yel
RF door + blu/blk
LR door + grn/blk
RR door + yel/blk
ground - blk
Switch burning bright
Moving on to the driver's master switch.
Remove dust seal from switch
The drivers master passenger actuators come apart just like the rear.
The auto switch has a shaft that slides out. It is shaped different from the others but CR-V matches the Accord.
Drill holes for 3mm leds as shown for passenger and rear actuators. The driver's auto led needs to be placed closer to the actuator so cut the plastic and glue led in. Use CA glue not hot glue as pictured. You will need to power the led and make sure it illuminates properly while gluing.
Run wires out to the side and reinstall the dust seal. Wire to car as desired.
Front finished. I ran out of blue leds so the auto received a red one.
lucifer1 is offline   Reply With Quote
Old 12-16-2014, 12:59 AM   #2
PhatAccord
PhatAccord is cool... so far.
Send a message via AIM to PhatAccord
Wow you sir, are talented.
PhatAccord is offline   Reply With Quote
Old 12-16-2014, 04:31 AM   #3
steelbluesleepR
I shoot people
steelbluesleepR seems to have made some friends!
yeah, THIS is cool. I love that no matter how old these cars get and how much has been done, more can always be found to do.
Originally Posted by Stephen Fry
steelbluesleepR is offline   Reply With Quote
Old 12-16-2014, 11:14 AM   #4
cp[mike]
ŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
wow this is cool! . Definitely something I am going to do for myself! Excellent work figuring that out.
Old 12-16-2014, 11:41 AM   #5
Jarrett
This looks a lot easier, and with a better final product, than my Legend window switches. Good job!
Old 12-16-2014, 10:30 PM   #6
c91bse7
c91bse7 is cool... so far.
What year was the crv these came from?
Originally Posted by Darkcloud View Post
Wimp go low or go home haha
Originally Posted by cb7_tillidie View Post
Not a single fuck was given that day.
c91bse7 is offline   Reply With Quote
Old 12-16-2014, 11:00 PM   #7
PakaloloHonda
PakaloloHonda is cool... so far.
Send a message via AIM to PakaloloHonda Send a message via Yahoo to PakaloloHonda
very very well done ..
PakaloloHonda is offline   Reply With Quote
Old 12-16-2014, 11:37 PM   #8
Maple50175
Gigity Gigity
Location: Good ol' Ma. Does it look like im kidding assholes! XM-BPM for life!
Maple50175 is cool... so far.
Send a message via AIM to Maple50175 Send a message via Yahoo to Maple50175
Sweet mod man.
Maple50175 is offline   Reply With Quote
Old 12-17-2014, 12:38 AM   #9
802cb7
802cb7 is cool... so far.
way to go. I actually messed around with my rear defrost switch last night. For some reason every bulb I get for it from the junk yard is blown, so I fashioned in a blue led just to see if i could do it, and it works great. A little out of place with everything else being greenish/blue, but its was a great way to learn. Awesome MOD and a great write up!!!! will be doing this in the future.
802cb7 is offline   Reply With Quote
Old 12-17-2014, 10:24 AM   #10
ambientwater
ambientwater is cool... so far.
anything different on a coupe? I assume everything would still fit the same correct? Awesome DIY though
Calling your USDM Accord "JDM" is like calling President Obama "African".
ambientwater is offline   Reply With Quote
Old 12-17-2014, 02:50 PM   #11
lucifer1
Yes, much easier. I wanted to do this before I did the legend ones but did not want to pay ebay prices to try.
1st gen cr-v later years 99-01
I don't know. If they are sourced from different manufacturers then maybe not. I know 7 gen civic coupe actuators are different from the 4 doors, rsx is same as coupe but 2nd gen cr-v use the same as 4 door civic.
Old 12-17-2014, 05:24 PM   #12
DAKOTADEMON7
DAKOTADEMON7 is cool... so far.
Very cool..Rep given.
1991 Accord LX .
DAKOTADEMON7 is offline   Reply With Quote
Old 02-03-2015, 03:54 PM   #13
1badacc
1badacc is cool... so far.
TTT great mod!
^^MY OLD RIDE
http://www.cb7tuner.com/vbb/showthre...91#post3052591 <<**CURRENT DA9 BUILD**
1badacc is offline   Reply With Quote
Old 02-03-2015, 09:36 PM   #14
cp[mike]
ŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
in case the LED wiring is unclear to anybody:
Each LED should be wired to the 12-volt "illumination" power source, by way of its own resistor. A resistor reduces the power leading to the LED to a range it can handle, so it doesn't burn out.
These tiny 3mm LEDs tend to require a voltage range around 2-3 volts, but as a general ballpark, usually a 560 Ohm resistor would work fine. 560-ohm resistors come in various sizes/wattages. In this case, a 1/4-watt resistor would be fine. The resistor can be connected to either pin of the LED, inline between the LED and the power source. Here's a wiring diagram as an example:
Old 02-04-2015, 05:52 AM   #15
lindiz
lindiz is cool... so far.
Great thread, really interesting. So only certain models have the "AUTO" letters on drivers switch illuminated? Is there a way to tell if it lights up by just looking at it on pics uninstalled?
lindiz is offline   Reply With Quote
Old 02-04-2015, 01:26 PM   #16
lucifer1
The lighted switches have an extra separate two pin connecter for the lighting. This connector has the standard red/blk and red backlighting wires in it.
Old 02-04-2015, 06:15 PM   #17
jdm_inspired
jdm_inspired is cool... so far.
Send a message via AIM to jdm_inspired
You're awesome bro! Definitely will be doing this in the near future.
Follow me on Instagram: @antscoe
1993 Accord EX
2011 Accord EXL
Click here for: eBaY iTeMs
jdm_inspired is offline   Reply With Quote
Old 01-05-2018, 04:11 PM   #18
excalibur02
Wanna be JDM whore
Reloaded the pics for lucifer1 since photobucket is blocking 3rd party hosting.
Instagram username MAURO02
Old 05-15-2018, 01:31 AM   #19
zedjr10
zedjr10 may have said something they shouldn't have...
so 99-01 crv would work. Does anyone know what other models would work on 92 coupe.
Old 05-15-2018, 01:25 PM   #20
NH-503P-3
NH-503P-3 is cool... so far.
Don’t bother with 91-95 legend lighted switches. They don’t fit or match up in any way.
~Mark~
