I just installed a Nuespeed front tie-bar last night (thanks again TEckert.)
Was a tight fit, with ALB components on one side and some cruise control pieces on the other. It helped some to remove a 10mm bolt on each side, one for one end of the ALB motor box and one that holds down three brackets on the other. But both bolts were a bit of a challenge to get back in so next time (um, like when I need to change the air filter ...) I think I'll leave them in.
I first got both arms on one side and the other side wouldn't line up completely. Re-did it the other way and had the same problem on the other end.
I raised the front end, to see if taking weight off would change the geometry enough to get that last amount of wiggle going to allow the bar to fit better.
Finally was able to wiggle it on but not completely flushed down, but enough to start the bolts and tighten them. I feel kind of lucky the threads on the strut mount didn't get ruined. That would have sucked to high-heaven.
When I started the car I immediately heard a droning that rose and fell with RPMs. Quite noticeable. Sounded like a bearing going bad in the power steering pump or somewhere close, but with this difference: I could also feel the driver's side fender vibrating slightly.
OK --- fender vibrating = new bar making the fender vibrate = what would cause the new bar to vibrate with RPMs? I noticed the power steering pump hose touching the bar, pressed down on it to clear the bar --- sound GONE.
Q: Would a shorter power steering belt allow the pump to be pulled closer to the head, thereby allowing the hose to better clear the bar immediately above it?
