Electrical Help
    Electrical Help
    Look at the image below. I've (poorly) labeled the components that I don't know. Can somebody tell me what they are? I know that some of them are transformers, relays, and one big ass capacitor, but I don't know what's what. In case you don't see all of them, there are 4 numbers.
    Also, does anyone know what the voltage drop will be if I extend 12 gauge solid wires maybe 3 feet?
    Bonus points if you can guess what this circuit will do....
    MRT
    sneaky motherfucker
    measure the resistance and that will tell you the amount of v-drop.
      I don't think the drop will be enough to impact what this is supposed to do. If it is, I could always use a bigger capacitor!
      Any help on the other items?
      MRT
      sneaky motherfucker
        I want to know what those components are!
        555 is a timer circuit, by the way.
        MRT
        sneaky motherfucker
          1. NPN BD679 Transistor
          2. 10nf/400 volt Capacitor, the triangles going into lines are 1N4007 diodes
          3. 10nf Capacitor
          4. 1k:8r Transformer
          Voltage drop also depends on the load going through the wire. A small load will have almost no drop.
            Thanks!
            I didn't even know that diodes existed before I read that. Wiki makes them sounds like a good invention.
            Care to guess at what this will do?
            MRT
            sneaky motherfucker
              Originally posted by GeoffMisiak View Post
              Thanks!
              I'm not sure...
              Start at page one and read EVERYTHING on this site.
              http://www.bcae1.com/
              You will learn pretty much everything about basic electronics.
                Well, here's the original image.....
                I used to know a lot about electronics, but most of it slipped my mind
                MRT
                sneaky motherfucker
                  looks like a 555 timer set to astable mode, output changes continuously. all aboard the pulse train
                  stun gun...
                    stun gun...
                    Guess what I want the 3 foot wire extensions for......
                    Go on, guess!
                    MRT
                    sneaky motherfucker
                      Go on, guess!
                        Here's one: If I'm touching the target, do I get it too?
                        MRT
                        sneaky motherfucker
                          bump
                          MRT
                          sneaky motherfucker
                            You already got it
                            Rephrase about what you get.
