Surgeon builds an engine
    It's the worlds smallest V12.
    MRT
    sneaky motherfucker
    Pushrod?!
    Amateur...
    Accord Aero-R
      Originally posted by CyborgGT View Post
      Pushrod?!
      Amateur...
      you wanna make 4 cams for that thing?
      pushrods make the packaging even smaller than it would have been, had it been an OHC engine
        now do an automatic transmission
          That's pretty damn cool.
          Was it just me, or did anyone else think he was rather forceful and clumsy (for lack of a better term) when building most of the valve and "crank" train? I'd be scared to have him as a surgeon...
            Surgeons can be and some are like that.
              His next project is to turbo charge this thing.
              A&P-IA
                Pretty damn cool.
                Originally posted by wed3k
                im a douchebag to people and i don't even own a lambo. whats your point? we, douchbags, come in all sorts of shapes and colours.
                  The top comment causes some concern:
                  It looks like it's running on compressed air.
                  MRT
                  sneaky motherfucker
                    One of the commenters that seems to have a brain said he's a watchmaker/jeweler, which makes more sense to me than a surgeon. Either way... dude had the time, money, patience, knowledge, and skill to pull this off! Awesome!
                    And anyone on there that's saying it sucks because it's not a real running engine can go suck an egg. As a fully functional model, this thing is amazing!
                      Definely a watchmaker. I only said surgeon because of the precision required to do this, like a surgeon.
                      Does anyone know what that tank looking thing is he put underneath where the plastic line goes in?
                      MRT
                      sneaky motherfucker
                        probably an air tank
                        PSN ID's:Tidashoni
                        1992 Accord EX Coupe
                        My FS Thread
                        Not so DD 2013 Subaru Impreza WRX STI
                        Boosting with a carb is like being a sniper with a bazooka... it works, it gets the job done, but it's not the most precise method.
                          fresh water tank
                          there's coolant pump installed, too.
                          A&P-IA
                            I found the builder's youtube channel. Apparently building miniature engines is his hobby.
                            Also, his explanation of how it works.
                            v-12 engine with compressed air injection,hand made using taditional methods:12 cm3 of displacement,the diameter of the cyllinder is 11,3 mm,the stroke of the pistons 10mm,it works with only 0,1kg/cm2.Is constructed with stainless steel,aluminum and bronze.Patelo dedicate this engine to his grandchildren:Sara,Carmen,Jose and Pablo.This engine is for education,exhibitons,etc.,that is the reason to work with compressed air, to avoid contamination.He has made the plans and all parts, except the screws.The engine is not for sale.Thanks to everybody for the comments and sorry for my bad English.
                            1992 Accord Wagon (RETIRED)
                              how come engine builders don't build the smallest engine? it'd only make sense.
