I bought these HIDs and instead of them lining off like about knee hieght they face off into the air and they are bright in peoples rear view is there a special way the bulb goes in or is it just the HIDs itself. ill try to get so pics this weekend and show u guys. O and i had the lamp all the way down and they just scattered everywhere.
HID question
You need to adjust your headlights. When you pop your hood look at the headlights, At the corner of them next to the fender you will see a Phillips head screw. Turn the screw and it will move the headlight up or down.Originally posted by rudeboy5I bought these HIDs and instead of them lining off like about knee hieght they face off into the air and they are bright in peoples rear view is there a special way the bulb goes in or is it just the HIDs itself. ill try to get so pics this weekend and show u guys. O and i had the lamp all the way down and they just scattered everywhere.
if they are off centered now then they were off cencered before.
Where you light shines has nothing to do with you HIDs.
Adjust your headlights like previously said
----------------My 92 Honda Accord LX---------------------- My 97 Nissan 240sx LE----
NE GUYS, Buy the last of my accord parts
As mentione readjust them and either way you are going to glare because of the reflective nature of the stock housing. Either way you need to retrofit.
Its called they will look like ass in a stock Accord housing because it simply wasn't designed for it. A good halogen projector can be upgraded to HID with reasonable results, but a regular reflector housing typically will not work well with a HID at all.
Yes, I know there are cars out there that have reflector housings and HIDs....they're not ideal either but at least the reflector was designed with HIDs in mind.
projectors in cb7 headlights looks disgusting. they done look right. he should be fine. my uncle has a cr-v without a projector and it looked sweet, now he got those *** ebay projector headlights. its still similar to stock lens, just more focused.Originally posted by NutBucketIts called they will look like ass in a stock Accord housing because it simply wasn't designed for it. A good halogen projector can be upgraded to HID with reasonable results, but a regular reflector housing typically will not work well with a HID at all.
Yes, I know there are cars out there that have reflector housings and HIDs....they're not ideal either but at least the reflector was designed with HIDs in mind.miss my turbo cb7
true that. my HID'S don't have any glare at all. I'll take a pic tomorrow. I don't have projectors either. just the factory headlights.Originally posted by NutBucketIts called they will look like ass in a stock Accord housing because it simply wasn't designed for it. A good halogen projector can be upgraded to HID with reasonable results, but a regular reflector housing typically will not work well with a HID at all.
quickangel: Some stock housings work better than other, I grant you that. In your uncle's case, it is true that most ebay projector headlights are total trash regardless of what bulb you use in them. Retrofitted CB7 housings may not look "right", but the light output so much better you won't care.
jhondayaaj: How can you agree with me and then say that your stock housings have no glare? That just doesn't make sense. At one point I did consider putting HIDs into blackhoused headlights thinking that it would cut down on the glare. I never did bother though. Glad I didn't waste my money on the kit at that time.
