whine from amp
    whine from amp
    I have a sqeeking whine in my speakers hooked up to the amp. The thing is it alternates sumtimes it does it and sumtimes it doesn't. I thought it was the ground but now I'm not sure. Any1 have some suggestions on what it could be? I have a kicker 4ch 400watt amp with kicker wiring.
    Does it increase in sound while you accelerate? Pioneer decks have the tendency to do this. Trying grounding your rca's by wrapping wire around the connection points. If this fails, but a ground loop isolator.
    Follow me on IG: @jdm_inspired
    93 'til infinity
      I like to take the head unit's ground wire and attach it to the metal bracket holding the dash in place, so it's grounded right to the chassis.
      How well is your amp's ground wire attached to the body?
      I had an amp that would pick up engine noise when it was cold from a bad ground-body connection. If you use a ring terminal to a stock (tail light) ground bolt in the trunk, or a self-tapping screw into the metal it should alleviate that. Your RCAs aren't run next to your power wire, are they? That's a nono too.
      PM me and get it done right!
        well. i do have a pioneer head unit and yea the whine increases with my rpms. so just any wire will do? also sadly i did run my rca cables next to the power wire. do they interfere with eachother somehow?
          the magnetic field around the power cable will mess with your signal. that's why it's always recommended to run them on opposite sides of the car.
          and as said, check ground connection at head unit & amp. sand paint away to shiny metal, put your ground together and then a quick shot of primer will keep it from rusting.
          Officially "hilarious mad sarcastic"! Thanks CB74christ for the recognition of my work.
            Kicker amps are notorious for engine whine.
            I have a bunch of the older DX amps, they have to have super solid grounds, also make sure your amp isn't in a "GROUND LOOP". Kicker amps are easy to ground loop.
            90 accord EX automatic F22A4 232,500
            DIY ram intake
            0gauge/4gauge BIG 3
            stock alt rewound to 120amps
            optima orange top 830cca 1030ca
            fully synthetic valvoline "Max Life" 5w30
            Other rides:
            2004 Jeep Liberty v6
            2001 Honda civic ex coupe 1.7 vtec
              do like lucid said and move the power wire away from the rca cabels. ( different sides of the car) Also make sure you clean the paint away from where ever you ground the amp. I would not use a tail light or any other trunk bolt. Try to keep your ground cable the same size as the power cabel and no more than 3 feet long if possible. The shorter the better.
                I sorta like my whine. It makes me feel like I have a turbo.
                With that said, thanks for the advice everyone.
                This is what I run.
                DUAL CD Deck
                Amp (exact model)
                私は日本語を話さない
                1990 Honda Civic DX - Junked
                1992 Honda Accord Si - Sold for parts
                Next Honda coming.
                  私は日本語を話さない
                  Nice one driftmaster.
                    What?...it's true! I can't. lol
                    私は日本語を話さない
                    Next Honda coming.
                      If you have a Pioneer deck, do this:
                      When I installed my sub, it had a sound that was like the exhaust was miked up to the sub. It was annoying as fuck. I did what they did in the picture, and now there's no hum at all even with the gain turned up. Pioneer H/U grounding sucks dick, but this quick fix helps immensely.
                      Originally posted by lordoja
                        Now, did you take your deck out just to take a pic of the back??
                        私は日本語を話さない
                        Next Honda coming.
                          Hmm never thought of doing that. Could you tie those into a chassis ground? My Pioneer has a separate connector for the RCA outs, which really blows.
                          Originally posted by chessboxer
                          We know these are good cars, but for some reason, all the world wants are freaking civics and tegs. Bleck.
                          Bought From: Slammed4thGen TypeG x2DeevergoteBillKisme
                            Yea people have done that. I was satisfied with just doing what's in the picture though. But for the best sound quality it would be best to have everything (radio, RCAs, amp, car) be tied into very close if not the same grounds. Not really possible though
                            No but it wouldn't be a big deal for me to do it, my radio is just sitting loose anyway
                              thanks for all the tips every1 well i routed my rcas and power wire seperately and i did wat my friend reccomended and wrapped it in aluminum foil. sadly that didnt work so i guess its the head unit. ima try wat that pic showed to do for the pioneers. cuz im now pretty sure thats wat it is. ill get back and post if it worked later today
