alternator upgrade
    Originally posted by darkfusion42 View Post
    The Voltage regulator is NOT in the ecu....its in the alternator housing.
    where the green plug goes.
    ^^^^ that is right its in the alt.....i was thinking about my old civic when i said that
    and the powerbasterds alt is crap buy an dc alt...
    My 90 coupe Mr thread....
    http://www.cb7tuner.com/vbb/showthread.php?t=178452
      On this site I have heard that the Lengend alternator won't fit and I have heard from from other sites that it will fit. I got one from the junk yard yesterday and am going to see for myself if it can. If it can I will take some pictures of it and what it takes to make it work. Wish me luck!
        Good luck man I hope it works!
          It does not work.
            Next I will try the Odyssey Alternator.
              I just got a vtec prelude alternator and it
              has 80 amps on the box, uuuurrgghhh... I waited all week for it too Does any one know if it just ses 80 amps on the box but is actually 90 amps?... Hope I didn't just waste my time
              4000watts just so all the haters hear me comin!
                Alternator took a crap on me, so I went to the u-pull it and got an alt from a 97 Ody. Bolted right in after I swapped the pulleys using an impact gun, probably could have gotten away without it if I didn't mind the extra 1 or 2 grooves sticking out past the belt.
                I'm not sure, but the tension bolt mounting point might be in a different spot, I had to put the belt on before putting the pivot/main bolt in. Whether or no, it's virtually a non-issue, and my car's running again with some extra power available to run an inverter.
                  The '95-'97 Odyssey shows to be a 90A unit and the '98 looks to be 95A when checking through www.oreillyauto.com. I don't know where the original 140A figure came from.
