Fog Light Wiring Questions
    In the near future, I plan to get foglights in the front and one in the rear bumper. In this diagram I wanted to wire both sets of foglights to #3. Now, don't laugh, but do I just keep the wires on the piece of metal (or whatever it is) with electrical tape? If not what should I use? Thanks in advance
    Originally posted by Ander View Post
    The fusebox in your drivers side footwell has a few places to draw power from.
    Plug 3 will only come on when your corners are on, so you could roll around with your corners and fogs, with no headlights.
    Plug 5 is always on, so if you wanted to use a switch later on, you could use this.
    My Baby "CLEO", Slowly Making Her Mine
    You can go to the junkyard and pick up the 2P connector that goes in there. I think it’s a brown one, you can find them in later model Civics or even on a CB7 if it has an accessory installed. I know somebody had a good explanation of the accessory ports and how to use them somewhere on here.
    MRT's:
    2001 Acura CL
    1991 Honda Accord SE
    Originally posted by Bad_dude
    If you turn it all the way counter clockwise, you activate the after burner full throttle. Lol. Then when you press it, boom, fast as the T-Mobile data plan chic.
      Driver's door panel.
        It's a 1-pin connector, not a 2-pin.
