What's going on cb7tuner fam? Hope all is well! I need some help! Give you a lil background about myself. I live in Raleigh, NC. Work at the Honda dealership in Durham. Been a automobile detailed for a solid one year now and new to the whole "car" scene. I have a 92 accord lx. Put a used motor in it and she runs GREAT! Too good. I'm coming from a 07 Tahoe and I'm mind blown!!!! Only problem I have comes from the radiator fan....... it only comes on when the car is off completely. I'm in the process of replacing the ac compressor and fan blower!!! Give me some legit help and I'll give you as much feedback as possible as soon as possible!!! Thanks and god bless!
Hook a young brother up!!!!
The radiator fan only comes on when it needs to. For normal driving, it may only come during extended idling. After shutting off the engine, the heat soak can cause the fans to come on for a few minutes after shutting it off. Do you have problems with overheating? Does your dealership still have a service manual around for a 92 Accord?90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
Yes I do have a problem with overheating. I've never let it overheat but that gauge does get pretty close! And about the service Manual I can check to see if we still have one tomorrow when I go in.Originally posted by fleetw00d View PostThe radiator fan only comes on when it needs to. For normal driving, it may only come during extended idling. After shutting off the engine, the heat soak can cause the fans to come on for a few minutes after shutting it off. Do you have problems with overheating? Does your dealership still have a service manual around for a 92 Accord?
If you know your car is overheating, that's where I would begin diagnosis.
First, you'll need to let us know if it's your radiator or your A/C fan that's coming on. And have you verified with the car up to temperature that the fans are not coming on with the engine running? Also, did you replace the water pump and thermostat with the new engine you put in?
Next, check the fan switches. There are two you need to verify the condition of. One on the thermostat housing and the other on the front water neck. The wiring is old and brittle and if one of those were to break, it would cause your radiator fan not to work.
Then, make sure you don't have any oil or bubbling in your coolant system. The bubbles will only present with the car running.
Assuming all of that is in order, you could remove the radiator and flush it, check the hoses for leaks, replace the radiator cap and fill with new coolant.
Any more information you can give us would be helpful.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
In the future, please make your thread titles descriptive of your problem. You'll find that many more people will help you if they have some idea of what your problem is before they even read the thread.
That, and it's in the rules. Usually, threads with non-descriptive titles simply get deleted. The only reason I didn't delete this one is because people have already taken their time to help you.
Yes the car is overheating and the fans are not coming on while the engine is running. Water pump and thermostat was replaced. I can check the fan switches in the morning. And now with the bubbles in coolant. How do you personally go about resolving that? It was some air it in last time I check and ran it all out for sure.Originally posted by Jarrett View PostIf you know your car is overheating, that's where I would begin diagnosis.
Hey I got that service manual btw!Originally posted by fleetw00d View PostThe radiator fan only comes on when it needs to. For normal driving, it may only come during extended idling. After shutting off the engine, the heat soak can cause the fans to come on for a few minutes after shutting it off. Do you have problems with overheating? Does your dealership still have a service manual around for a 92 Accord?
Hey my apology man! I had no clue. I'm completely new to this whole forum thing but I'll make sure to be more descriptive in the future. Thank you!Originally posted by deevergote View PostIn the future, please make your thread titles descriptive of your problem. You'll find that many more people will help you if they have some idea of what your problem is before they even read the thread.
That, and it's in the rules. Usually, threads with non-descriptive titles simply get deleted. The only reason I didn't delete this one is because people have already taken their time to help you.Last edited by Jarrett; 05-21-2017, 10:14 PM.
Now would be a good time for you to look over the rules, then. Then you'll know what is expected of you.Originally posted by Gloman300_ View PostHey my apology man! I had no clue. I'm completely new to this whole forum thing but I'll make sure to be more descriptive in the future. Thank you!
I had this same issue with my CB when I got it. The car would never overheat but let it idle for a couple minutes and the temp would shoot up, no fans kicking on but if you shut the car off they would kick on for 5 minutes or so.
You may not be as lucky but all I did was throw in like 3/4s of a bottle of antifreeze and let it run with the radiator cap off for a few minutes.
Now it wont overheat while idling in hot weather and I can hear and feel the fans kicking on when they should. Fans still turn on after shutting the car off if Ive been doing city driving.
Check your fluid level in the radiator and let her burp any air out.
