post ur daily car problems here!
    Originally posted by CB7 Sleeper View Post
    F20a swap. Woot Woot!
    single or twinz
      Can I just say sir, that your car is very attractive.
      Why thank you good sir!!! it also has a slight vacuum leak so
      Click Here To Check Out My Ride
      http://www.cb7tuner.com/vbb/showthread.php?t=137030
        Brake booster leaks
        idles at 1k and 1.3k with lights on
        wat?
          the bolt i put in place of the pin in my clutch pedal fell out....again. no start for me.
          instead of pulling the pedal and re-installing, i yanked the plug and crossed the wires. no more clutch needed to start.
            Originally posted by F20A CB7 View Post
            single or twinz
            DOHC, built and on the bottle. You'll see, it will be in the car come spring. Then I'll reveal the finished product.
            R.I.P. Veronica - JDM F20A swapped 2.0 Si wannabe.
              Nice, lol.
                No, don't turn it all the way down. Unplug the IACV and adjust the screw until the tach shows your running at 500 rpms, then plug the IACV back in and the idle will go up to the correct rpm and stay there. This is the right way.
                Where's the IACV on the H22? I know where it is on the F22 but I have no idea for the H22...is it hidden?
                *Needs*
                -New shocks
                -Struts
                -Drop
                -Cleaning
                -New Tires/Wheels
                -New Window Tint
                -Alot more lovin'
                  My car has an oil leak from hell. Living in an apartment complex, I can't work on it. That and the weather has been cold as shit, so my car just sits. I weep when I see it
                    ok with mine. i have several liitle issues. when i start it sometimes it turns on right away some times it takes more cranks. my cat is clogged. my exhaust hangs about 1/2 inch from the ground. my header is cracked at the top. cant get my car to idle. my tach doesnt work. and the timing is off by a tooth or two. it works when it wants. havent been able to do anything to it yet due to cold weather. havent been able to work on it cuz of the cold weather and tomorrow might be the day were i fix the timing. i really wanna see my tach work at all times any advice on how to fix it????
                      every time that i fill up i get this gas smell in my car when going down the road with the window crack and when i open the door to get out its bad to but no signs of leaks.
                        its the little white plug on the side of the plenum near the butterflies
                          So why post? Just asking.
                          My car is parked in the backyard! The transmission is shot! So I'm in the process of an F20a swap. Woot Woot!
                          Because im happy i dont have any problems ( yet )
                            Well I hope you didn't just jinx yourself.
