coolant resevoir removal?
    how do i remove the c.r. ?
    i've read a bumper removal diy as well as the manual, but pics would really help.
    -thanks
    My 1992 honda accord LX 5 spd.
    "Behold! What was once thought to have been
    buried beneath the sands of time,
    the ill-fated Haynes Repair Manual has been resurrected
    from the depths of a watery grave." - LX_Accordian
    It's really easy. Take off the cover and pull it straight up. It should slide up from the holder. If it's snug, spray some wd40 on the holder and that should help
      Yeah, if the holder is getting good 'n rusty it may be a pain if it hasn't been removed in a long time.
      Opal Metallic Green '92 LX 2dr manual, 181k miles, '94 prelude VTEC wheels for summer (steelies with snow tires for winter), Omni-power struts/springs, and other junk
        the cover of the resevoir thats attached to the thin rubber hose?
          Just open the cover and take it off. Leave the overflow hose/tube on. It will also be a good idea if you siphon the remaining coolant on the reservoir so that it will not spill/splash on you while you are pulling the reservoir out...
            what if i left the cover on and tried to yank the resevoir out after spraying it with wd40?
              That OK too...
                k
                  May I ask why you are removing this item?
                    i'm removing the bumper to install a lip, and i dont want to remove the battery because thats what i did before and its a hassle to reset the clock and all.
                      Hasle...lol 2 minutes to reset your stereo vs the time your wasting now to try and remove the CR?
                      MR Thread
                      GhostAccord 2.4L Blog
                      by Chappy, on Flickr
                        well it is one less step to do...but idk..removing the battery is just easier for yourself in taking out the CR IMO..
                        *Needs*
                        -New shocks
                        -Struts
                        -Drop
                        -Cleaning
                        -New Tires/Wheels
                        -New Window Tint
                        -Alot more lovin'
                          wow it is not that hard to remove . . . you take the cap off and pull it up how is that confusing to you. You talk about it like there are a whole bunch of peices on it; " the cap with the rubber hose connected to it?" No the other peice that is there but you can't see cause its invisible. There are TWO fucking peices to the resivour the cap and the resivour its self wtf you just pull up on it and next time you decide to ask about how to do this you coulda just spent the time disconnecting the battery and or reconnecting it and setting your clock.
                          F22b + MP1A = mad fun for me now. . .
                          MY RIDE
                          My swap parts list and pricing
                          vouches:
                          Bought from: Smeagren83(quite a few times now LOL), 97lude, AZaccord, M3torz2nR, g7kobayashi, sickoffthe206 and Kurobei, Jarhead, prNonVtec4u, caserX
                          Sold to: Snailin91, Smeagren83, cb7dazz, Drummersteve7, Slick
                            lol dood..chill...the guy is probably new.
                            *Needs*
                            -New shocks
                            -Struts
                            -Drop
                            -Cleaning
                            -New Tires/Wheels
                            -New Window Tint
                            -Alot more lovin'
                              yeah but he said he read the manual I have the manual he has it is not that hard to pull the resivour. . .
                              MY RIDE
                              vouches:
