Alright fellas, I have a 92 accord, LX, Automatic. Haven't been on the forum for a while. Anyways, Whenever I pull off from a stop, say a stop sign, or light. My car won't go, and if I want it to go, I have to hit the gas for a few seconds to get it going. Once I'm around 30 mph I'm good to go. Transmission fluid is good. Any other ideas?
Bogging/Lack of power.
Tags: None
Will do, thanks.Originally posted by H22WAGON93 View Postcheck your vacum lines and your distributer
Nothing really man. Just driving it.Originally posted by skilzz View Postfuel filter, plug wires, bad engine grounds, there is so much shit.....
wat did u do to your car prior to this happenin
Originally posted by C91BLX7 View PostSounds like your TCU/ Solenoid isn't working.
Try stopping, Putting the car in 1 then manually shifting to 2, then 3,4.
If it works fine you just need a TCU.
i may have this problem, i usually manual shift when im playin around and it doesnt bog. when im in just 4, it picks up a little sluggish, then gets power at around 2krpm and doesnt lose power at all. only when im taking off in d4 is when i feel it. i was also thinkin about my plug wires, bosh with ngk plugs, any suggestions?
RIP to my SexyAuto
you just say the car "wont go"
do you mean it revs and wont move? or wont rev at all90 accord coupe-f22a4
jdm accord inspire emblem, jdm cb3 sidemarkers, black bumper and amber corner lenses, 92/93 trunk swap with red/clear tails, ebay muffler, sri, p12 ecu, clock from a 95 gs-r(amber diy soon maybe), da teg headrests, almost too low drop on no name springs with aftermarket struts =] (dont hate, im poor!)
r.i.p 91 coupe r.i.p 90 4dr r.i.p 88hondalegend c27a1 5 SP!
i <3 my cb7
www.myspace.com/eryeryerr
Sorry, haven't been able to get on. Still doing the same thing.Originally posted by ..gzagenius View Postyou just say the car "wont go"
It won't go until I hit the gas for a few seconds. Then it gets power. I'm kind of thinking it's my cat, because I hear a rattle under the car, don't know how to explain it, when I first take off.
Originally posted by jdmtypecb7 View Posti may have this problem, i usually manual shift when im playin around and it doesnt bog. when im in just 4, it picks up a little sluggish, then gets power at around 2krpm and doesnt lose power at all. only when im taking off in d4 is when i feel it. i was also thinkin about my plug wires, bosh with ngk plugs, any suggestions?
Same here around 2,100 RPMs, it holds there for a second, then I push the gas, and it revives itself. I always leave my car in D4, so i'm having the same exact problem you are. Figure anything out yet? Anybody else have any suggestions? I'm about to hit up Autozone for some new Spark Plugs, and Wires. Try the eastiest things first....
Originally posted by cleanwithit0607 View PostSame here around 2,100 RPMs, it holds there for a second, then I push the gas, and it revives itself. I always leave my car in D4, so i'm having the same exact problem you are. Figure anything out yet? Anybody else have any suggestions? I'm about to hit up Autozone for some new Spark Plugs, and Wires. Try the eastiest things first....
c92blx7 said replace tcu, which i believe is 'transmission control unit'. anyone wanna confirm this?
RIP to my SexyAuto
Ok I went outside and messed around with it. When I put it in 1st and go, it's perfectly fine;good acceleration. But then I put it in 2nd, 3rd, 4th, and it runs like crap. I did the manually shift thing, at a stop. Could you please explain to me why I should try that?Originally posted by jdmtypecb7 View Postc92blx7 said replace tcu, which i believe is 'transmission control unit'. anyone wanna confirm this?
Yes, Transmission Control Unit(TCU)Last edited by cleanwithit0607; 08-15-2008, 11:23 AM.
