Squeaky power steering
    Depending on the kind of squeaking I would surmise it being the belt. If it's a constant "sqeeeaaaaaaak" I would bleed the system. If it's more a 'sqeeEeeAaaak" I would replace the belt. It's kind of hard to explain, but I think it's probably a belt. Bleeding the system can't hurt though.
      I recently noticed that my power steering hose was leaking. So I ordered one from advance auto.
      After changing the hose It made the "wet fingers on glass sound" all the time. I thought It might have been the pump. So I went to the JY and got another pump same thing. So then I got to looking at the hose The new hose was smaller in diameter than the stock one. Hum?
      So this prompted another trip to the JY. I grabbed the best looking stock hose. Replaced it today, quiet power steering again.
      My theory was the rack was starved for fluid.
      Obviously the hose isn't your problem but I believe the rack is not getting the fluid it needs. Probably your pump.
      advance $100
      JY $20.
      Steve
        Everything i've read in this thread ( the old and the new posts ) points to bad ball joints ( upper or lower ) or tie rods ( inner or outer )
          You are correct.
          The wheel movement makes you think ball joints. When mine went out It was like a clunk when I went over bumps.
          My power steering problem was more of a constant thing in my case.
          Upper A arms are about $50 from advance with lifetime warranty.
          steve
