Exhaust Manifold Swich
    Im just being curious about this question. Could the H22 exhaust manifold fit on the F22?
    And If not, does the F22A4 and A6 have the same style exhaust manifold? I know the A4 has the header lookin one but im not sure about the A6.
    H22 exhaust ports are spaced differently than the F22 so no, an H22 manifold will not work.
    The a1 and a6 have the same type of cast exhaust manifolds while the a4 has the more open header-type manifold.
    I'm currently running the DC Sports header, but many people claim that the stock a4 header flows almost as well. It's a good alternative if you're on a tight budget.
    My Member's Ride Thread
      i jus upgraded to the A4 an it knocka alil at the bottom of my crossmember i think i''ll just grind some off an it'll be fine other than that u'll also need the downpipe if u chosse to do the A4 swap which is alot cheaper than any aftermarket header. w8 i think the o2 sensor are different as well hmm i think they are reversed on the A4 M/F the A1 F/M correct me if im wrong meaning u'll need to extend the wire dependin on ur IM.
      Summer 11' Big plans (Bodywork/paint/rims etc..) in Progress STAY TUNED
      CLICK THE PIC
        A1 and A6 are both cast, but not the same. A6 is more of a cast header and flows better.
          Thanks for the correction, I should have known that....
            yea the o2 is different too between a1 and a4/a6. i put an a4 on mine, and ghetto rigged it to work. i stretched the wires to the back of my motor(where the a4 o2 is located) then spliced the a1 o2's plug on to the a4 o2 sensor... never had a problem
