i just bought/installed a cheap ass ebay stainless steel header and downpipe. now my car makes this squealing noise. it usually depends on how hard i press the throttle and i usually begin hearing it about the same time i hear my short ram growl. it does however start to go away as i near redline. wat is this? it almost sounds like a belt squeal, but i know its coming from the exhaust. i also have a gutted cat... so wat is causing this noise? anybody with a similar problem?
ebay header
try adjusting your idleOriginally posted by sxyhnda View Posti just bought/installed a cheap ass ebay stainless steel header and downpipe. now my car makes this squealing noise. it usually depends on how hard i press the throttle and i usually begin hearing it about the same time i hear my short ram growl. it does however start to go away as i near redline. wat is this? it almost sounds like a belt squeal, but i know its coming from the exhaust. i also have a gutted cat... so wat is causing this noise? anybody with a similar problem?
usually with ebay headers, you'll notice some vibrations around 2-2.5 rpms. I think its because of the poorer quality and manufacturing of the pipings. And if the squeal is actually more like a vibration then I think a possible cure is to heat wrap the header. Or beat yet, save up more money and buy a DC or one of the better name brand. Have fun!
its like a whistle/squeal/rattle... lol hard to explain.... excuse my stupid question, but wat does thread lock do and how would that help? i was also begining to wonder if thats just the way they sound. a musical instrument makes noises when you blow thru tubes, maybe it was just the way it was designed and it makes noises as air passes thru it
峠 で ドリフト を して 下さい。
俺 は
