so today im just checkin out usual stuff like my oil and coolant levels and when i started my car i heard a lil knocking from my motor. it sounded like it was comming from the block but i wasent sure. could it be my valves tapping?
any1 have any ideas on what it is?
the car still runs normal i just hear the knocking. it does have 186k on it
alsoo with all you guys with gauges
for the air/fuel gauge what color wire on the 02 sensor do you connect the gauge to? my 02 is heated with 4 wires.
for the boost/vacuum (for now) what vacuum hose works best so that the gauge reads something.
for the oil pressure gauge where does the sensor that came with the gauge hook up to one the car? is it above the oil filter? what size bolt is that also.
