Weird My Car Wont Go Pass 5000 Rpm, Dont Konw Whats Wrong With It. Can Somr1 Help Me?
weird my car wont go
Yes But Since I Put In The F23 On It Its On, I Can Floor It An It Just Wont Go Pass 5000 Rpm. I Can Hold The Gas Pedal All The Way Down For 30 Min N It Would Stay At 5000 Rpm But Just Release The Gas And It Goes Into The Next GearOriginally posted by tonymontana1204 View Postis The Check Engine Light (cel) On?
WHAT U KNOW ABOUT THAT?
dude im not tryong to wast no one's time, i posted here because with all this cb7 maybe a can get some help. i diren't change the ecu is the STOCK(f22) one thats in the car n it was ruing find, i know that the v-tec was not kicking in do to not being connected. thanks 4 all ur commentesOriginally posted by Jonas View Postso your running a non vtec ecu with a vtec motor? maybe thats why it wont work over 5000rpm.
or do you mean the ecu for the f23? be more specific if you want help. otherwise your wasting peoples timeLast edited by f23accord; 11-22-2008, 04:26 PM.
You have a point. the only time you're wasting is yours. When you ask for help, give as much info as possible, then the people who can help you will know what you're working with. So, are you up and running or not?Originally posted by f23accord View Postdude im not tryong to wast no one's time, i posted here because with all this cb7 maybe a can get some help. i diren't change the ecu is the STOCK one thats in the car n it was ruing find, i know that the v-tec was not kicking in do to not being connected. thanks 4 all ur commentes
Your previous posts make it sound as if you had an f22ax in the car. You then swapped it out for an f23 and since you've installed the f23, you have a CEL and the engine won't go past 5k. You said that you are also still using the non vtec ECU from the f22ax, which is probably where the problem is. The ECU from the f22ax that ran the old motor fine won't run the vtec at all. We all understand the frustration with your car, but the more information you give us, the less we have to work to fix your ride....Since I Put In The F23 On It Its On, I Can Floor It An It Just Wont Go Pass 5000 Rpm...
