well since the past week the temp rises up when im at a red light for a couple minutes and as soon as i start moving again the temp lowers back down to normal temp, my guess that it may be my water pump if you have any ideas let me know thanks
over heating any ideas?
It may "work" but sounds like your fan is not kicking on. you can jump the wires at the fan switch by the thermostat to see if your fans turn on. If they do, it might be the switch that's bad, if they don't it could be a fuse or bad fan motor.
I had problems with my fans not kicking on after I put in the new radiator. Turns out the new radiator is just that much more effecient that they hardly ever run at all.
not necessarily, a stuck shut thermostat can cause the same affects. , but it would overheat while driving as well and get higher in temp when parked.Originally posted by visualpoet View PostHow are you sure? Your symptoms say fan. The water pump being out would overheat moving as well as sitting. No airflow across the radiator means overheating at rest, but not in motion. No waterpump means overheating, period.
i'd say if your fan is working, then it would be the thermostat, if the fan isn't working, get that fixed and then see if your overheating continues, if it does, replace the thermostat, if you still overheats, and would be unlikely if it hasn't been changed in forever, then it would be the water pump.
good luck
-Ox
My bad, I forgot to mention a stuck t-stat. I haven't had one in my coupe since I got it, and was just complaining about the lack of heat when the car is rolling and it's cold as shit outside, so I should have thought about that as well.
Since both fans were visibly running, Ox has probably pinned it down.
Originally posted by visualpoet View PostMy bad, I forgot to mention a stuck t-stat. I haven't had one in my coupe since I got it, and was just complaining about the lack of heat when the car is rolling and it's cold as shit outside, so I should have thought about that as well.
Yeah all that. And go head and change your thermo while you at it cuz that shit is easy as hell.Originally posted by CB7Dominican View Postyou should also bleed the radiator because the coolant lines might have air inside them and that will cause the engine to overheat. if that doesnt work you should check your temperature sensor. see if that will solve your problem.
