my 90 cb7 is spiting and sputtering while driving at 2000 rpm's ,but when i down shift it goes away and when i push in the clutch it goes away. the check engine light comes on after a period of driving. i checked it today b/c the problem is getting worse. the code it through is a code 43(fuel supply system).this all started when we got the bad ice and snow weather recently .so anyone got a clue what is wrong with my car or, anyone ever have a problem similar to this with there car?
code 43
I had the same problem for months and months. changed the fuel pump, fuel filter, fuel injector cleaner, changed the spark plugs.....
It was ridiculous. I don't recommend dropping or putting a fuel tank alone. its a bitch and a half.
Anyways I changed the o2 sensor and it was like driving a new car. CEL went away and hasn't *knocks on wood* come back. The one that was in was only about a year old maybe.90 LX (R.I.P.) http://www.cb7tuner.com/vbb/showthread.php?t=137301
91 EX (DD) http://www.cb7tuner.com/vbb/showthread.php?t=142483
Yea dude. Just get a new o2 sensor. I'm surprised you aren't gettin' a #1 too. #1/#41 codes normally lead to #43. When an o2 sensor's bad, your car will run rich. Do NOT go cheap on the o2 sensor. The first o2 sensor I purchased was a bosch. It lasted for about....nah, it just didn't work at all. I recommend the Denso. www.carpartswholesale.com I got mine for 80 bucks shipped, and it was definitely worth it. Don't waste your money at Advance gettin' the cheapest. Remember to reset your computer also after the install, so the codes get deleted.98' Mustang 3V Swap
11' VW CC R36
well if your Fuel Filter is original....change it right now. That would mean its over 15 yrs old. But yeah my next suggestion would be like everyone else, O2 sensor could cause that code to come up b/c its related somewhat, since it tell the engine how much fuel and air to add etc, etc.
First off, the bosch o2 sensor works just fine, (got the ex one for 57 bucks) you have to go to the bosch website and get the wiring diagram, and use the original harness, soder then electical tap and walaa.
mine wasnt working before i found the diagram, then i rewired it, sodered the connection, because i heard if the resistence is off by 1 ohm it will throw a code.
43 is a fuel system code, change your fuel fiter and run some cleaner threw the next time you fill you tank up. it should fix it, especially if your JUST throwing 43. and not 1 and 41_____________________________
91 Accord F22B
Yeah, ive been dealing with this code on and off for awhile now. At one point I had 1,16,41,43, now I just have code 43. It all seemed to stem from awhile ago when my o2 sensor came loose. I replaced it. I changed my coolant, the next day these codes pop up. Anyways, recently, I fixed a leak I had in my EGR system, reset the ecu, made sure the ecu was properly grounded and no shorts in the wires, and it seems to have improved it. The next time you throw this code (generally its when the car is warming up and it will switch into open loop and this is where it throws the 43 and goes into safe mode. Now when your car does this, turn off your car for a few seconds and then turn it back on. For me, if I do this the code goes away. I think it has something to do with the o2 sensor heater not working properly on initial start up. This is a finicky code to diagnose so...
Oh ya, apparently, from what Ive read from a few good sources. Code 43 got lost in translation...what it really means is that the system is seeing unburnt oxides in the exhaust. So for whatever reason, your car is running in a rich state.
Originally posted by preludejim View Posti changed my o2senser last year
so that's not it.
That IS it. Those replacements don't work correctly. Get a Honda o2 sensor.
I'll have to look into Slice One's statement a bit further. It'd be nice if that actually works... Most of these threads have one or two people saying "I use the bosch, and it's fine!" and they have no idea why. For the first time, someone actually presented a proper fix...
Yeah no doubt dude, the reason i looked it up was the fact that I know that bosch wouldnt keep selling these o2 sensors knowing they are almost all defective, and i replaced mine and 2 weeks later is was throwing 1 41 and 43 and i knew it wasnt defective, so what i did was a WHOLE shit load of research, and the bosch website has a STOCK HARNESS to REPLACEMENT wiring diagram it lists 4 types of typical stock wiring color formats, and tells you which is which to go from stock to replace right. I might do a write up on it. but the diagram deff said if resistence is off by 1 ohm it will throw a code, and more/less resistence can be caused from spliced wires, hence the need for soder to close the opening in the wires. like i know the ground for the o2 heater is suppose to keep a 8 ohm resistence, so thats probably why it throws the 41 code, heater isnt grounded right so it wouldnt work properly... sounds about right, right?
Anyways it worked for me. Plus i used silver soder, it cost me about 15 bucks for 3 feet. LOL_____________________________
91 Accord F22B
If you didnt know, Bosch invented the o2 sensor, so how they suck, i dont know, like i said its all about what your willing to do, I know for a fact resistence play a factor in the operation of the o2 sensor and spliced wires def cause more/less.
think of it this way
60 bucks for a uni o2 4 wire sensor VS. 190bucks for a Denso
I got mine operating correctly so ill keep my 130 bucks for something else thank you very much.
If you have a UNI and its throwing codes, get the diagram from here
PDF LINK
http://www.boschautoparts.com/NR/rdo...orInstall.pdf/
Its right on there, and it tells you why if you dont soder or use wire nuts it will malfuntion. they say they wont even garuntee the o2 sensor if ou dont follow these directions._____________________________
91 Accord F22B
