what bearings can i use on a turbo h22a that are strong and i can daily drive and run hard with out spinning a bearing? and can i use stock h22a rods with turbo setup ?
turbo rod/main bearings
Use new OEM bearings with correct clearances.
You graded your crank and rods?Originally posted by 3tcRob View PostI graded my crank and rods and am putting stock Honda ones back in tighter clearances and I had over 320k on my other motor before arod bearing spun
Don't make the clearances tighter than OEM specs. You can put them at the tight end of the spec but don't go outside.
My 5.7 LS1 Holden Ute
NO its not the same, but close. I will post the details after its done.Somthing to do with crank angle grinding =) Trying a few things out, diff rods from diff engines.Originally posted by coupe View Post^not sure but i dont think it is the same in/outside diameter. but i am currently building my f22a. this is my first f/h series. but i have had great luck with acl bearings in all my b series engines
278 whp 266 wtq.
