Has anyone here taken there radiator out before and if so did you have to take the fans off? Is there a dyi or some website that explains it. Thanks.
Radiator
There's probably a diy about it somewhere. Just search it.
You have to take the fans off. It's really easy to take it out. I replaced mine with an aluminum one.
Slamage is worth the Damage
Originally posted by crazymikey"Yes, we did officer. By the way, your eyes look a little glazed, did you just come from the donut shop?"
I have replaced my radiator. It is really easy. Let the car cool down, drain the coolant, pop off the hoses to the radiator. Remove the bolts for the fans, slide the fans out, remove a couple more bolts and remove the radiator. The hardest thing to do is to reinstall the new radiator and fans without damaging the fins on the radiator in the process.
^^^X2^^^Originally posted by CAMILOSI View Posteasy way to do it is by removing radiator with fans on and swapping the fans on the ground that way u don't damage the fins on ur new radiator.i have done it that way a dozen of times with no problems.good luck.
The radiator can be removed and installed with fans attached. Ive done it plenty of times also.
^^^^ x3 .. you can take the radiator out with fans attached. The only thing that might get in the way is the a/c lines .. just push them out of the way and also don't pull on the place where the upper radiator hose goes because they are also known to snap off too if they are brittle. Just take your time and if it seems like its stuck just look what is sticking and move it out of the way... if yours is automatic just make sure to disconnect the two radiator hoses which can be done right there in front of the trans.
