How much of a pain would it be to remove all the cruise control components? I say this because mine doesn't work and I seen on someones member ride thread that they took it out for weight reduction. Is this an easy task? And what problems might I run into?
cruise control removal
We are all ricers, it just depends what flavor rice you are.
Minitrucker by heart, CB7tuner by coincidence.
My For Sale Thread
Bowling Pin Shift KnobsTags: None
I think its the easisest think to remove. One of the members said it took him 5-10 mins i belive. All you really need to do is unhook the cable from the gas pedal unbolt the bigg ufo looking sensor and pull. I think thats how it goes.The past, is history:The future, is a mystery:The present, is a gift.
James 4:7
Submit yourself to God. Resist the devil and he will flee from you.
I just want it outta the way because it doesn't work on my car and it's really serving no purpose. Plus it'll help clean out the engine bay a little.We are all ricers, it just depends what flavor rice you are.
My For Sale Thread
there's an electical connector on the servo part under the hood. unplug that and then start the car to see how it does. my 90' freaks out with the cruise unplugged and revs up to 1200-1300 rpm. doesn't fluctuate at all, just goes high and stays there.Officially "hilarious mad sarcastic"! Thanks CB74christ for the recognition of my work.
Its probably because you didn't cap the vacuum line. There is one rubber hose running to the servo, and you MUST cap it by putting a screw in it ect.Originally posted by lost_accord View Postthere's an electical connector on the servo part under the hood. unplug that and then start the car to see how it does. my 90' freaks out with the cruise unplugged and revs up to 1200-1300 rpm. doesn't fluctuate at all, just goes high and stays there.
That would be a vaccuum leak... The cruise control on these old cars works off of engine vaccuum, whatever the engine vaccum is at the point of setting the cruise control is what the servo (aka "UFO") measures. So when you unhook the vaccuum line fro the servo(UFO) it creates a vaccuum leak. Follow the line back to the intake manifold and plug it off, simple as that. Your engine will run just as it did before you took it off.Originally posted by lost_accord View Postthere's an electical connector on the servo part under the hood. unplug that and then start the car to see how it does. my 90' freaks out with the cruise unplugged and revs up to 1200-1300 rpm. doesn't fluctuate at all, just goes high and stays there.
What do I do with the cable coming from the gas pedal once I remove it?We are all ricers, it just depends what flavor rice you are.
My For Sale Thread
I'm not really doing it just for the weight reduction. My cruise control hasn't worked since I got the car. I just want to take it out to clean up the engine bay a little because its really useless. Thanks for the input from everyone.Originally posted by rexload View Postthere is also a black box behind the drivers side fender with some vac lines going to it and a small control unit under the dash you can remove. you can also remove the button from the steering wheel, the whole thing is under 5lbs though :-(We are all ricers, it just depends what flavor rice you are.
My For Sale Thread
What do you do with he cable going into the diaphram (ufo)? i know you loosen the two 12mm screws for the adjustment but how do you pull it out?
I went to do this the other day at work and got to this part and didn't wanna mess anything up, so I bolted everything back down and figured I'd ask you guys.We are all ricers, it just depends what flavor rice you are.
My For Sale Thread
bump.We are all ricers, it just depends what flavor rice you are.
My For Sale Thread
