cruise control removal
    Originally posted by konig52r View Post
    I think its the easisest think to remove. One of the members said it took him 5-10 mins i belive. All you really need to do is unhook the cable from the gas pedal unbolt the bigg ufo looking sensor and pull. I think thats how it goes.
    do u mean the big cylindrical diaphragm looking thing on the drivers side?
    They rise their wooden pints and they yoik and sing
    And they fight and dance 'till the morning
    Dont forget my MRT for my 1992 Honda Accord LX
    Everything in Japan is made with carbon fiber and used panties.
      Originally posted by Tnwagn View Post
      I had to cut my cable when removing the system. You can try and pull it through from the engine side, but if it won't go through the grommet, just cut the wire.
      It unscrews from the firewall. Anyways it takes no more than 15 mins to get the thing out. It cleans the engine bay up alot.
      "The Turtle"
      DD/Trail Rig/Mud Bug
        so is it that big cylendrical thing on the drivers side?
          Yeah, right next to the power steering resovior. There will be a cable running into the fire wall. You have to undo it from the gas pedal and then unscrew the cable. Then you have to take all the vacumn lines out and you'll need a plug for one of the nipples.
          "The Turtle"
            where can i get the plug?
              Auto zone or Advance.
              "The Turtle"
                whats it called?
                  whats it called?
                  Just looks for vacuum caps and try to remember about what size you need. I think its like a 1/4" cap.
                  And does anyone have any solutions for taking the cable out of the diaphram? Or should I just unhook it from the pedal and remove it as a whole unit?
                  We are all ricers, it just depends what flavor rice you are.
                  Minitrucker by heart, CB7tuner by coincidence.
                  My For Sale Thread
                  Bowling Pin Shift Knobs
                    remove it as a whole unit. once its unhooked from the pedal just rip that crap out.
                    93 accord coupe lxr
                    10 fusion se slammed
                      Is there an official write up on here...? Pictures and all..?
                        no, but its simple.
                        1. go to your gas pedal. unhook the cable at the very top of the pedal.
                        2. go to your engine bay. unbolt the circular thing. 2 or 3 bolts.
                        3. unhook the plug.
                        4. go to your firewall where the cable goes into, and twist that piece then pull cable out.
                        5. put a rubber cap over the vacuum line on the intake manifold. should be on the back.
                        6. done....
                        very simple
                        93 accord coupe lxr
                          easy takes 10mins.
                            Originally posted by 1991f22a1 View Post
                            i unhooked mine when i changed the steering wheel. then removed it completely when i did the intake mani swap. race cars dont need cruise control
                            What do I do with the cable coming from the gas pedal once I remove it?
                            ____________________
                            how to download ps3 games to your ps3
                            how to copy ps3 games
                              Yank the gas pedal cable through the firewall and throw it away when you throw away the bulbous cruise control thingy you unbolt from the engine bay. I understood that much.
                              But when I looked at my bulbous cruise control thingy in the engine bay it looked like there is a 1inch-ish diameter hose coming out of it and going directly down into the fender well. No one's mentioned that. What is it and what do I do with it?
                              90 Accord Ex, F22A4. Slight fire damage.
                                there is two cable at the top of the gas pedal ( throtle and cruise ) and there both really close to each other. the question is which one to unhook or if your going to cut which one to cut.
