Originally posted by ar design
View Post
turbo on 10.5:1
If the OP wants 250whp, there is no need to use forged pistons if the tune is good. Therefore, stock compression is what he has to work with... which is below 9:1. If you are going to run forged pistons, sure, raise compression... but the stock compression is low, and quite safe with a good tune. Stock low-end power isn't terrible with these cars either.
Agreed. Statement was made with the assumption that the motor was being built.Originally posted by deevergote. View PostIf the OP wants 250whp, there is no need to use forged pistons if the tune is good. Therefore, stock compression is what he has to work with... which is below 9:1. If you are going to run forged pistons, sure, raise compression... but the stock compression is low, and quite safe with a good tune. Stock low-end power isn't terrible with these cars either.
You sound like you know quite a bit... so it's certainly doable! I think we've seen 400whp on a stock block. That was a track car only, though... and it DID eventually give out. But it put up with quite a bit of abuse before it did!Originally posted by ar design View PostYup. Building my setup on a stock longblock, shooting for 300whp. We shall see
I don't expect it to last forever. Its just kind of a fun project, I have a few other cars so no big deal. Need an excuse to build a forged motor anywaysOriginally posted by deevergote. View PostYou sound like you know quite a bit... so it's certainly doable! I think we've seen 400whp on a stock block. That was a track car only, though... and it DID eventually give out. But it put up with quite a bit of abuse before it did!
And I will probably tool around on 200whp, turn it up with an EBC when I need it.
I think I was at a Shell station and they had 93, I think it might have been in Natomas. I know I've seen it in Sac someplace.Originally posted by joe_bernardi View PostYes I will be rebuilding my f22a with forged pistons and rods. will I be able to do this on 91 octane they don't have 93 in sacramento ca.1992 Prelude S w/swapped H22A
