Calling all F22 experts
    Hey ive bin doing my research on the F22b1 head. Everyone says it pretty much flows horribly and even though its a vtec its not really an upgrade the f22a. Is there a way to change this? A port job or anything to make it flow better? I have an F22b1 laying around and my F22a1 isnt getting any younger. Im thinking about doing a swap soon. Please shed some light
    not an expert, but any ported B1 head will definitely be a +++!
    the vtec for this motor is more for economy purposes and not power.
      The port design is crap. The ports are restrictive due to the design of the VTEC system. No port job will make it flow better than an F22A head with equal work. The valve angle also sucks. The VTEC system is also on the intake side only... it's not really very similar to the more performance oriented VTEC found in the DOHC motors.
      The F22A has a near ideal valve angle, and the head flows VERY well. I've heard reports from more than one head porter saying that it flows as well as, possibly better than, a B18C5 head (ITR).
      If you want to do a project, do it to the F22A. Putting any money into the F22B1 head is a waste.
        The F22A has a better flowing head, and better valve geometery, and ...?
        The f22b1 may have vtec, but its only on the exhaust side which was designed for fuel economy not performance.
        Best thing to do would be to take the f22b1 bottom end and swap your f22a1 (from what i've heard, the blocks are pretty much the same)
        Just take the opportunity while you have the f22a1 head off to get some work done to it, either p&p, or upgraded valve-train.
          my f22ax head bolted up to my b1 block with no problems/modifications
          Formerly 91AccordExR33
          11.68 @ 127mph
          417whp/375wtq
          Sold: 8/2016
            [QUOTE=cloudasc;2102354]The F22A has a better flowing head, and better valve geometery, and ...?
            Just take the opportunity while you have the f22a1 head off to get some work done to it, either p&p, or upgraded valve-train.[/QUOTE
            my f22a1 head has a whole lot of miles on it. i was hoping to add some life to the car with the younger head. for the sake of drivability is the f22b1 any good? i guess i just didnt want to do the classic h22 swap that everyone is doing. is it possible to switch the head without taking the whole engine out?
              For less then $500 counting machine shop labor for resurface/mill & 3-angle valve job, you can totally refurbish your f22ax head, new valves, seats, springs, retainers. Thats what I'm having done to my f22ax head in the next couple days, upgrading the springs while i'm at. The real reason to yank the head off is the headgasket is weak and i'm getting exhaust gasses building up in my cooling system, since its coming off, I just couldn't slap it back on without doing anything to it.
                I think I saw rebuilt F22A heads on ebay for around 150 or 200 bucks.
                  slap an f23 intake manifold on it.
                  NEW CB
                  old Darkcloud : 1990 Accord EX MRT
                  new
                  DARKCLOUD : 90 ACCORD EX MRT
                    So the shitty flowing head can have more air thrown at it?
                    It's like putting a pair of Air Jordans on a cripple.
                      I just laughed, so very hard...
                      Seriously though, finding an F22A with fewer miles shouldn't be that hard if you are legitimately worried about your engine's mileage. Get one in good running order from a junkyard, swap it in, and rebuild (or have rebuilt) the engine you pulled out.
                      Besides, as long as you keep fluids in your F22a, it'll probably last you a long time even if it's worn. Sell the F22B1 to some guy with a 5th gen.
                      MRT(vvv) --Stock CB7 Enthusiast #1--
                      Vouches: new_beginnings, ThrakBarts, beanzfynest617, JaK FRoSTWhiTE, 92_EX_Ninja, mak
                      i am with the dumb. i cannot brain.
                        Everyone kinda skipped this... and Lee knows more than I do!
                        Are the blocks really the same? I thought some modification had to be done...
                          dude you can swap heads without taking the motor out lol
                          to achieve a Fuck, you must first give a Fuck
                          Follow me on twitter @tru_whitetrash
                            Built, ported, cammed f22 head on a h22 block at 9000rpm mmmmm
                            wat?
                              Why do you need an H22 block for that? The H22 isn't made to rev to 9000 either! If you're going to put that much money into the F22 head, put the money out to build the F22 block to rev as high as your head needs to make power.
