A few months ago I got a full service oil change. They checked my brake fluid, said it was dirty and needed replacing. Ever since, it's been slowly leaking so that I need to fill the reservoir every month. It looks like the fluid is coming out at the bleeder valve, or in any case it's moist under the caliper.
Is it likely they sampled the fluid at the wheel, and ruined a gasket when they opened the bleeder? Should I replace the bleed screw? (And deal with all the fluid draining out?) Or just put liquid gasket on it?
