Best intake manifold/throttlebody upgrade
    I've heard that the F22B, H22A, H23A and other intake manifolds can be bolted right up to the F22A block so I'm just wondering which one is the best to bolt onto an F22A block or if any of them really are direct bolt on? Thanks!
    Learn to read the stickies and to use the search function. You'll find that 99.9% of your questions regarding your car have been answered already. Check out this thread, it will get you started on performance mods.
    http://www.cb7tuner.com/vbb/showthread.php?t=88154
      H23A is the only one listed there that will work. That is the best option we have.
        Okay, I had already looked there and only saw the h23 intake manifold, but I know I once asked skunk2 if they had any intake manifolds that would fit my car and they said the h22 manifold was the manifold that bolts on directly so I wasn't sure which way to go.
          Skunk2 knows nothing about 4th gen Accords.
          And if they told you that the h22 manifold would bolt in... then I actually just lost a bit of respect for them. A respected company shouldn't be giving out bad advice, especially if it is in regards to their expensive products.
            Well I'm glad I didn't buy one then. But is there any difference between the H23 vtec and H23 non-vtec manifolds? I would assume the vtec one would be larger and better but I'm not entirely sure.
              the h23 never came with vtec, at least in america. what engine do you have right now? if it is the f22a6, you can just put an h23 or h22 plenum and throttle body on your stock runners. if you have an a4 or a1, then you'll need to get the whole manifold.
                The H23 VTEC is much more like an H22. I don't know for sure, but I would assume the port spacing and bolt patters for that motor are like the H22. The H23A1, USDM only, is the one you are looking for parts from.
                The H23A1 intake plenum and throttle body are identical to the H22A. The lower part that bolts to the head is what is different. This upper part (the plenum and throttle body) will also bolt to the F22A6 lower half. Some say it is better... I have not been able to compare directly myself.
                  I have the 10th anniversary accord, no idea which exact number it is.
                    You have an F22A1. You'll need to replace the whole manifold with either the H23 manifold, or the F22A6 manifold (which is an upgrade in itself) with the H22 or H23 plenum and throttle body.
                      Which one is the best one, the H23 plenum with the F22A6 black box?
                        The black box doesn't matter where it comes from.
                        People have said that the H23 plenum with the F22A6 runners is the best combination. No dyno proof has been provided, so it's all in theory. The difference is probably minimal... and since you'd have to buy both manifolds to make the hybrid manifold, I'd say just stick with the H23 manifold.
                          Okay, so the H23 manifold has a black box too? Is there like a picture somewhere? And I'd need a new EGR, IACV, etc wouldn't I? Or can I delete some or all of that?
                            The black box you do not need. To run the iabs(butterflies, just run a vac. hose from the diaphram to an intake vac. port.) The egr depends on your states emission laws. You will need the iacv and the other valve that is on the tb.
                            "The Turtle"
                            DD/Trail Rig/Mud Bug
                              It's best to run the IAB system from the ECU as it was designed (you'll need the PT6 ECU that runs the F22A6 as well), but vacuum is an option. I don't like it that way myself.
                              As for all those other parts listed... find a complete H23 manifold, and anything you need should be attached.
