F22A1 swap need help!
    Originally posted by TryingToSwap View Post
    I put in a F22a1 motor from a prelude into my 93 accord and it runs but it idles and has no power.
    This statement does not make any sense. Please make concise statements that accurately portray your situation, you will get better responses.
    Also, you clearly are not familiar with setting physical timing (cam timing/timing belt alignment) based on your previous statement of the flywheel rotation and not being sure if that messed things up. If you did know how to set physical timing properly, you would not have asked this question and have understanding.
    Therefore, how can we/I have any confidence in your statement that you set timing properly? Also, there are two different types of timing (ignition and physical).
    If you are unsure of how you set either types of timing, then atleast describe what/how you checked it. Then, we can assess your method to be correct or not and go from there.
    You're not the only person that does this on the forum, but MANY are so quick to say they did things correctly and rule that out. Later to find what they were so quick to overlook/assume to be correct, was the problem.
    You want helpful answers? Describe in detail your problem and in what idling/driving situations it occurs, all you have tried/done and your methodology.
      Originally posted by hondafan81 View Post
      this Statement Does Not Make Any Sense. Please Make Concise Statements That Accurately Portray Your Situation, You Will Get Better Responses.
      Also, You Clearly Are Not Familiar With Setting Physical Timing (cam Timing/timing Belt Alignment) Based On Your Previous Statement Of The Flywheel Rotation And Not Being Sure If That Messed Things Up. If You Did Know How To Set Physical Timing Properly, You Would Not Have Asked This Question And Have Understanding.
      Therefore, How Can We/i Have Any Confidence In Your Statement That You Set Timing Properly? Also, There Are Two Different Types Of Timing (ignition And Physical).
      If You Are Unsure Of How You Set Either Types Of Timing, Then Atleast Describe What/how You Checked It. Then, We Can Assess Your Method To Be Correct Or Not And Go From There.
      You're Not The Only Person That Does This On The Forum, But Many Are So Quick To Say They Did Things Correctly And Rule That Out. Later To Find What They Were So Quick To Overlook/assume To Be Correct, Was The Problem.
      You Want Helpful Answers? Describe In Detail Your Problem And In What Idling/driving Situations It Occurs, All You Have Tried/done And Your Methodology.
      Damn Dude! Chill Out! Im A Fuken Noob To This, This Is My Very First Swap, Thats Why Im On Here Asking Questions Trying To Figure Out What I Need To Go Back And Look At, Dammmmmn!!!
      And I Had A Buddy Who Has Done Timing Before Check It For Me!!
      Im Sorry If I Dont Explain Sht Well Enough Ill Try To Do Better Next Time. Mutherfuker.
        Someone tried to help you, and explained how to get better responses, and you act like that?
        See you in 7 days.
        My 5.7 LS1 Holden Ute
          7 days? You're too kind. I've been permabanning probably more than I should.
            Must this guy capitalize Every Letter Of Every Word?
            How does he do that???
            *Needs*
            -New shocks
            -Struts
            -Drop
            -Cleaning
            -New Tires/Wheels
            -New Window Tint
            -Alot more lovin'
              He Typed In All Caps, Like This. The Software Changes It To Every First Letter.
              Djmoua, Your Sig Is Too Big. Drop That Last Pic Please.
                fasho!...the guy decided to keep his cb7 anyway haha
                *Needs*
                -New shocks
                -Struts
                -Drop
                -Cleaning
                -New Tires/Wheels
                -New Window Tint
                -Alot more lovin'
