clutches..?
    clutches..?
    i want a stage 1 clutch i think...
    what brands are good clutchmasters? exedy? etd?F1?
    Click it.... You know you wanna
    Bought from:Joshy,H22WAGON93, nho93accord,90accordLXGUY,phantomCB7,Tommi
    Out of the ones you listed, Clutchmasters or Exedy.
      i had the f1 for a while worked great till i broke every spring on the clutch disk with a stock f22a. they are under rated.o as for ur ? exedy is the best in my opinion.
      my new turbo build
        tha clutchmasters one is pretty cheap but more then the f1... im really looking hard at it so if any1 has experiance with it please post
          The real question should first be what are you planing to do with the car...
          keep it stock?
          build motor for N/A?
          slap a turbo on the motor?
          I'd recommend Exedy. but stage 1 might not be the best for you depending on what your future plans are.
            future plans being just a h22 and the h22 lsd tranny.. maybe do some mild work to the h22...
              ACT makes decent clutches.
                i've had 1 f1 clutch and the rest were all exedy clutches. i wouldnt recommend the f1 clutch to anyone. exedy has some nice clutches in my experience.
                The Hatch < < - - - - - - - - - - - - - - My Cars - - - - - - - - - - - - - - - > > The Accord
                  Any cheap clutch isn't worth it. Exedy makes OEM clutches, and if you're not putting down over 200whp, Exedy is the most affordable and reliable option out there.
                  Any real performance clutch is going to cost money. If it's cheap, it's not going to last, and it might cause damage (my cheap XTD setup all broke at once... clutch, throwout bearing, pressure plate, flywheel... EVERY component failed together!)
                    ok so ill get the exedy oem for now thanks guys
                      Stage 1 exedy should fit the bill nicely
                        Im going with a H22a,H22a tranny,Phantom Grip LSD,Bisimoto Flywheel and a Bisimoto STG 2 Sprung Clutch.Its good for 500 hp. The stg 1 is good til 275hp. I might go with Stg 1 but my goals are over 275hp so prolly not.
                          I'm running the Exedy organic clutch and an ACT streetlite flywheel. I've been very happy with the clutch, I've got just over 30k on it and I auto crossed this summer with no problems either.
                          http://www.cb7tuner.com/vbb/showthre...=1#post1823428
                          My Custom BB6 Dash Swap Thread
