Is seafoaming safe?
    Is seafoaming safe?
    I been watching alot of video's on youtube about seafoaming & researching on my own. I want to know is it safe to use? Will it damage the cat converter?
    what did your research tell you??
      http://www.superhonda.com/forum/f20/...d-idea-332017/
        I've heard mixed things about it myself, never used it. The one thing many have told me is that it isn't safe to use on an EFI vehicle
        life is good.
          I have used it countless times on every honda I have ever owned and I have NEVER had any problems with it. It cleans the carbon off the valves and will idle a little better if its never been done. I usually run one can through the tank and then afterwards I run one through the brake booster hose. Its the best fuel system cleaner out there hands down.
            I did it to my civic, ran it through the gas if I remember correctly. Didn't seem to improve anything, but didn't seem to harm anything either. So if it did some good for my engine I just didn't notice it. I did however run some of that oil crap through the engine that's supposed to stop leaks and that did absolutely nothing. Wish I could remember what it was called cause I'd tell you not to waste your money on it.
            http://www.cb7tuner.com/vbb/showthre...=1#post1823428
            My Custom BB6 Dash Swap Thread
              seeing people seafoam their cars is insane. especially if they driving in the streets, leaving a trail of white smoke wherever they go.
              I do not know if it supposed to be environmentally friendly, because is sure doesn't look like it (sorry for sharing my EPA thoughts)
              Originally posted by visualpoet
              some owners think it's the best thing since titties
                So anyways do I just pour 1/2 of seafoam on pcv valve with the car on right? so after that I turn off the car & wait 10 or so. Do I pour the other half to the gas tank or before turning the car on.
                  If you put it in your crankcase, you should change the oil twice to avoid damage. Of course, I ran for 4000 miles with seafoam mixed with Mobil1, and it didn't seem to hurt anything... but that was REALLY stupid, and I was lucky!
                  I never put it through a vac line... that always scared me, that I'd do it wrong.
                  The fuel tank seems to work well as well.
                    Bardahl Stop Leak & No Smoke
                    And I've used this in mine and it did make a difference, mind you, my car may have been going through oil worse than yours
                      u ran it with ur oil? I find that more risky then using the vac lines.
                        Don't forget about Amsoil Power Foam. I've heard good things about that as well. Probably more a bit more expensive though.
                          i was going to use this too...i was gna put 1/4 in the oil cause i gotta change mine soon anyways...
                          and the rest in the fuel on a full tank before a long trip...
                          can is 10 bucks so if it works like in the videos then i dnt see it bad i just heard you gotta do it every like 5000 to 7500 miles so every oil change?
                          ill try it and take a video cause i wanna see it :]
                          i dont see it being any worse then the fuel cleaner i already use
                          .My Ride.
                            I've used seafoam before. It works pretty good. The real test would be to not use it, take off the cylinder head and inspect the carbon build up. Then reassemble everything, use the product then dis-assemble the head again to see what it did. It's more for the sake of SCIENCE than anything but it would tell the truth about seafoam.
                            What I like to do is run a vacuum hose from my intake manifold after the TB plate and run it into the cab of the car LOL then drive down the highway and seafoam the hell out of it. People behind you give some pretty weird looks. But I do try and do it safely and not smoke screen anyone.
                            Been a long time. Still alive...
                              So your driving and pouring at the same time?
