Oil keeps leaking into my spark plug area do you think that seafoam will fix it?
Engine Additives
Oil leaking into your spark chambers would most likely be the seals at the top of each chamber, they sit underneath the top of the VC. Go ahead and order a set of those, try replacing them, and see if it solves the problem
http://www.cb7tuner.com/vbb/showthread.php?t=152259
life is good.
yeah again seafoam will not fix the problem, seafoam is only meant as a fuel system/intake cleaner, and even the oil additives that state to fix leaks are only a bandaid for the problem if they do work the first time when added to your oil. Simply put, a leak is a leak if you don't have the time and money to fix it now try an additive and see if it stops but you will eventually need to get the leak fixed it must be done.
1992 Accord LX 4-Door Automatic 360000+KM Mileage
"If it speaks Swedish and it needs work, it's going to be expensive."
Most auto parts stores carry seafoam. In my area that would be like CSK/O'Reilly, NAPA, or Autozone. Might be different in your area but I think you get the ideaOriginally posted by weezy911 View Postwho the hell sells "seafoam"?
Also to the OP, you might want to just get a valve cover gasket kit instead of just buying the seals for around the spark plugs. If those seals are old and worn out enough to start leaking, chances are the other gaskets are as well. I bought the whole kit, and when I took the VC off the main gasket was cracked and hard as a rock
Its not too much more to buy the kit so I say if you have the extra money go for it
I agree with RUGER 2.2L might as well change out everything, it won't be more than 30 bucks to do and will save you possible future grief. And like deevergote said never use stop leak products they not only stop leaks but also stop your engine from operating correctly, they do more damage than good.
