All I can think of is that he adjusted your throttle cable so there's less slack in the line giving you quicker throttle response. All my friends used to do it to their cars, however when one of them did it to my accord about 8 yrs ago before the h swap, right after we finished installing my cold air intake on the f22 it screwed things up. He tightened it a little too much and sometimes the rpm's would not drop back down to 800 at idle. They'd stay around 1500, so letting the clutch out could get tricky and it felt like I was taking off faster because you'd get jerked back like when launching at higher rpm's. I loosened it back up to the point where it didn't do that anymore cause it was annoying.
It's not a special "mod" at all and really isn't necessary. The only reason there's adjustment on the throttle cable is cause over time it can stretch. Messing with the tension is probably something you just shouldn't concern yourself with anyway.
As far as being faster, no probly not.
not everyone has much exp. with their cars, knowledge we take for granted is not so common out there.
