runs rough between rpm
    hey guys, im having a problem with my car the other day a hose blew and leaked all the anti-freeze the car over heated wouldnt start.
    Next day i noticed the problem fixed the hose & it started. now when i start my car when its cold i hear a whinning noise coming from the timing belt; it idles fine but once i start driving between 1,500-2,500 rpm the motor shakes as if its mis-firing or it wants to stall; but once i pass 2,500-3,000 rpm it runs fine again as if nothing were wrong.
    i honestly never seen anything like this what could it be?
    2004 Accord Sedan CM6 (daily)
    Koni Yellows, Hood Bra,Splash Guards,Deck Lid,Weather Mats,Sunroof Visor,Fog Lights <-All OEM, Mugen Door Visors, 07 Tsx Wheels.
    1990 Accord Coupe CB7 (project)
    H22 Swap, Skunk2 Springs on Koni Str.t, Rear Disk Swap, Fog Lights, 92-93 Trunk Conversion, 02 Accord Rims
    Take off the dizzy cap, dry it out with a clean rag, reassemble. If that doesn't fix it, come back and tell us.
      ok thanks i'll check it out during my break;; how bout the whinning from the timing belt? couldve it gotten loose?
        okay i checked out the dizzy cleaned it and seems to still have tht problem; any other ideas?
          Blown headgasket.
          Have you checked the sparkplugs yet?
          My 5.7 LS1 Holden Ute
            Originally posted by evil_demon_01 View Post
            Blown headgasket.
            not the spark plugs yet; but a blown head gasket wouldnt my car b smoking out the tail pipe or leaking oil/antifreeze? ive driven the car this week alittle & neither oil or anti-freeze have gone down. i just checked them both 2day.
              The whining may be your water pump.
              A blown head gasket may not smoke noticeably if it's not bad yet... but it could still affect the combustion. Check the plugs (take pictures and post them if you don't know what you're looking for) They will tell you if you're looking at a blown gasket.
