is primarily an O2 sensor code. i personally wouldnt bother checking actual fuel components.
O2 sensor signal wire is either high, shorted or the o2 sensor itself has failed (usually low voltage)
in closed loop, O2 sensor feedback is directly related to injector pulse width.
after you replace the o2 sensor and it still has a code, you need to check the voltage and see what the voltage is. if it is still lean, see if it will go rich with carb clean or propane enrichment.
if it reads rich, make a lean condition like a large vacuum leak.
-get a denso for a lower model accord like a dx or lx and just change the plug over. it will save you a couple bucks and if you do everything right it wont affect a thing.
