So I had oil leaking into the top of the spark plugs bad. Burnt my lower plug seals hard and crispy crunchy. So I pulled the valve cover and rocker assembly, replaced the upper/lower seals, valve cover gasket and new spark plugs, and that's it. Went to start the car and idle bounces and almost stalls.
Especially if i take it out for a drive stop at a light and very very close to stall so I had to put it in neutral and rev to like 2k and drop into drive to keep from stalling. Once it warms up really good, it seems ok. Cleaned the Idle valve for the heck of it, no change.
Maybe I over torqued the lifter assembly? Or maybe under torqued it? I don't know what else might have happened. Did I just botch up the timing somehow?
92 LX Auto H22A1. Nearly all stock.
